Glowshift Oil Filter Adapters? Do they fit?
Old Apr 16, 2008 | 03:57 PM
blueshawk's Avatar
blueshawk
Default Glowshift Oil Filter Adapters? Do they fit?
Has anyone had clearance problems with their oil filter after installing one of these
http://www.glowshiftdirect.com/index...amp;ProdID=303
It looks close to the sway bar but even closer to the radiator hose bracket. Has anyone noticed that the engine may enough for the filter to hit the hose bracket?
Old Apr 16, 2008 | 04:22 PM
ohnoesaz's Avatar
ohnoesaz
Default RE: Glowshift Oil Filter Adapters? Do they fit?
You'll probably have problems. I tried to install an oil cooler with a sandwich adapter, and it was a similar size to that, and there was no chance of making it fit. Now, I have a larger aftermarket sway bar so that affects it too, but like I said there was NO chance of it fitting, so with a smaller stock swaybar it probably won't fit either.
Hopefully someone on here can give you a direct exerience with this adapter....
Old Apr 16, 2008 | 05:16 PM
blueshawk's Avatar
blueshawk
Anyone have experience with this adapter????
dudeguy421
Sep 24, 2015 11:16 AM
Ford_Dude
Sep 15, 2015 03:25 PM
EASTIDEE123
Sep 15, 2015 11:08 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
kevsgt
Sep 9, 2015 06:20 AM
