Third brake light decals
Old Apr 20, 2008 | 07:01 PM
boomer123's Avatar
boomer123
Default Third brake light decals
I got a black decal for my third brakelight that has text in it....but in order for it to go on smooth, i need to get rid of the lettering on the bottom of the lens. Wondering how anyone else went ahead and removed the lettering without scratching the lens?
thanks, colton
Old Apr 20, 2008 | 07:22 PM
Aziraphale's Avatar
Aziraphale
Default RE: Third brake light decals
I removed some lettering from the fuse box cover and the short of it is ... just leave the lettering and deal with it.
You could try sanding it off but it's going to screw up the whole lens something aweful. The only other thing I can think of is to use an exacto knife and you might be able to slice them off but they might look white and be more visible and worse than when you started.
Old Apr 20, 2008 | 07:57 PM
FyouGitive's Avatar
FyouGitive
ORIGINAL: boomer123
thanks, colton
You can work the lens material just like you do the finish on your car: use a sharp X-acto knife to cut the lettering down, or file it with a nail file or emery board, rub it out with fine sandpaper and rubbing compound or paint-cleaner compounds. If you restrict the area that gets scarred, it may be worth it. As aziraphale said, it would be easy to mess it up and you might wish you hadn't started. I sliced them off, gave it a couple strokes with a nail file, and called it good enough.
Old Apr 20, 2008 | 08:02 PM
boomer123's Avatar
boomer123
yeah i just filed it down, scuffed the lens a little bit, but it will be covered up by the black anyways =) thanks guys
Old Oct 8, 2011 | 02:27 PM
luckydawg003's Avatar
luckydawg003
Just put my third brake light decal on my car. Tried grinding the lettering off but it ended up looking worse so I just put the decal over the raised lettering. It doesn't look that bad.
Old Oct 9, 2011 | 07:21 AM
Nuke's Avatar
Nuke
I put that decal on our V6. I sanded the letters down. Tape off the rest of the lens. Also, I replaced the OE bulb with a brighter Sylvania. Looks great.
Old Oct 9, 2011 | 08:39 AM
Lifter583's Avatar
Lifter583
Good idea...I will do that...always thought the light could be more even brightness
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
