Sponsored by:
Sponsored by:
Nitto Drag Radial NT555R 305/35/20's
Old 04-20-2008, 10:20 PM
sawyer
sawyer's Avatar
Default Nitto Drag Radial NT555R 305/35/20's
Anyone try these, and what do you think?
sawyer is offline
Old 04-20-2008, 10:32 PM
Blue Meanie
Blue Meanie's Avatar
Default RE: Nitto Drag Radial NT555R 305/35/20's
I run the 275/40/17 555r as a drag radial and it's mediocre at best. At your power level they'd be less than useless.
Blue Meanie is offline
Old 04-20-2008, 10:38 PM
Gene K
Gene K's Avatar
I think they might be an okay street tire if you are big on stylin'.
For the strip 15" all the way. Either Boggies or Holeshots. If you need a cheaper wheel wait until the middle of next month and you should be able to get Greg Welds for $100-150 or so from Summit to fit an 2006.
Gene K is offline
Old 04-20-2008, 11:08 PM
sawyer
sawyer's Avatar
I will have slicks for the track, I need a street tire to hold around 520 RWHP.
sawyer is offline
Old 04-21-2008, 01:04 AM
Blue Meanie
I wish I had that problem.It's definately more street biased and about as good as you can get for the money.
Old 04-21-2008, 01:20 AM
Orion_240
Orion_240's Avatar
don't get a drag radial for the street. Get a street tire.
you can't control when or where there can be water on the road and I have a feeling you'll just end up another statistic by driving around on drag radials![:@]
Orion_240 is offline
Old 04-21-2008, 03:38 AM
Androdz2
Androdz2's Avatar
there are radials that can hold that HP but on a 20 inch rim you are really trying to push it. I doubt the new 305/35/30 will do anything if the 305/35/18 have enough trouble already wouldn't want to imagine on 20's BTW I can't believe you still have that motorcraft battery after what I saw on ur picture lol
Andrew
Androdz2 is offline
Old 04-21-2008, 03:57 AM
Androdz2
Androdz2's Avatar
where is my sig..
Androdz2 is offline
Old 04-21-2008, 04:57 PM
moosestang
moosestang's Avatar
ORIGINAL: sawyer
Good luck with that. I'll never use a drag radial for everyday driving again. Mine put me into a viscous slide that I couldn't correct. They hydroplane to easily. I don't think any 20 inch tires is going to grip with your power, drag radial or not.
moosestang is offline
Old 04-21-2008, 10:54 PM
SaddleUp
SaddleUp's Avatar
maybe try the Nitto Invos......
SaddleUp is offline
Quick Reply: Nitto Drag Radial NT555R 305/35/20's
