Sponsored by:
Sponsored by:
Eibach pro/cdc aggressive???
Old 04-22-2008, 06:54 AM
matt07GT
matt07GT's Avatar
Default Eibach pro/cdc aggressive???
I plan on getting the eibach pro kit...but I just put on the cdc aggressive chin spoiler. I plan on doing a 1.5 drop all the way around. So....will I have clearance issues? Or should I be ok. Does anyone have this set up?
matt07GT is offline
Old 04-22-2008, 09:40 AM
06Redfire3V
06Redfire3V's Avatar
Default RE: Eibach pro/cdc aggressive???
Hmmm...I think it will be close. Are you planning on getting aftermarket rims and tires? or keeping the stockers
06Redfire3V is offline
Old 04-22-2008, 10:21 AM
Argonaut
Argonaut's Avatar
I have Eibach Pro with stock front and 27" diameter tires. Its low enough that I have to worry about pulling up to sidewalks and parking bumpers. I haven't yet had a problem with any speedbumps or steep driveways. With the agressive though....I think you would need to be very careful unless you are running a larger diameter tire.
Argonaut is offline
Old 04-22-2008, 10:56 AM
TOMBSTANG
TOMBSTANG's Avatar
you will be fine you just have to drive like your car is lowered [8D]. I have the aggressive and sportlines(not installed yet ) but I have seen other cars just as low with same set up and dont have issues. It looks sick
TOMBSTANG is offline
Old 04-22-2008, 11:11 AM
matt07GT
matt07GT's Avatar
ORIGINAL: 06Redfire3V
I actually have a set of 18x9 GT4's sitting in the basement and am getting Nitto Extreme 555's 255/45-18's............not sure if that would make a difference
matt07GT is offline
Old 04-22-2008, 11:14 AM
loaded6shooter
loaded6shooter's Avatar
i plan on dropping mine within the next few monthsbut cant decide between the pro-kit or sportlines. you really just have to change the way you drive.....back in to every parking spot, take inclines/speedbumps at an angle, etc.
hey tombstang if you dont mind can you hook it up with some measurements once you get the sportlines on? i cant decide if the sportlines are too low or not.
loaded6shooter is offline
Old 04-22-2008, 11:16 AM
loaded6shooter
ORIGINAL: matt07GT
i just put on a set of 255/45-18s in the front and some 285/40-18s in the back and the car sits noticeably higher, at least to me. its enough for me to consider sportlines
Old 04-22-2008, 11:20 AM
PullMeOverRed05
PullMeOverRed05's Avatar
ORIGINAL: loaded6shooter
ORIGINAL: matt07GT
i just put on a set of 255/45-28s in the front and some 285/40-28s in the back and the car sits noticeably higher, at least to me. its enough for me to consider sportlines
Hmmm.. I think you mean 18's, right? You sure would notice a difference with 28s!!
PullMeOverRed05 is offline
Old 04-22-2008, 11:31 AM
loaded6shooter
woops my bad lol....silly fingers
Old 04-22-2008, 11:46 AM
PullMeOverRed05
That would be sitting higher than my F150
Quick Reply: Eibach pro/cdc aggressive???
