Bad Gas... I hope...
RE: Bad Gas... I hope...
I think I may have figured it out...
I got under the car today after work and got to looking around. Last time I had a smaller but similar issue, I had just gotten my new Bassani X-haust installed that same day, I just attributed it to bad gas due to filling up at a station I'd never been to and the problem going away with a new fuel filter. I may have actually moved the wiring of the O2 sensor...
So, I got to looking around, and sure enough one of the O2 sensor wires looks like it's stretched and crimped near the base from not being long enough. I decided to hook the laptop up to my predator and car tonight, did a couple runs and wouldn't you know it, the voltage to the O2 sensor is WAAAAAAAAAAY off and it's coming up between -30% and -90% enrichment on the bank 2. Voltage was at 0.0000 at one time, hovered around 0.002+/- and on the other sensor it was usually around 0.8200+/-. Explains why I was getting lean codes too
Give me your theories...
I'll be replacing both of these sensors, as well as getting the BBK O2 Extensions since I'm sure I'll be upgrading the headers as well. Should be the fix to the problem though.
Fuel system is fine after further investigation.
ORIGINAL: jaguarking11
Another reason I got water in the fuel was, I filled after a rainstorm in an old gass station. Older gass stations have leaky tanks that saturate with water when there is very heavy rainfall. There was a recent news story about a nj gass station that had a line of cars that completly quit running after filling up there and there was a line of cars wating to be towed.
with sensors inside the second liner to detect the slightest leak of fuel.
There should NOT be any older gas stations using the old unapproved
leaker tanks since the year 2000 or so. So the groundwater leakage into
old tanks theory is not applicable unless you buy your gas from the
deliverance gas station in rural bumsville thats under the governments radar.
ORIGINAL: RojoDojo
I had just gotten my new Bassani X-haust installed that same day.
Cant diagnose when we dont know the story 100%. []
OCTANE BOOSTER'S KILLED MY PLUGS and did the same "thing" as you describe!!!!!!! my money is one a shot set of plugs!!!!! IMO, go ahead and order them....also, try the advise of cleaning the TB and reloading the tune, but stay the hell away from Octane Death......i have never used sea foam, but i heard it is a good product.....the only thing i will EVER put in my tank is good ol' 93 because it is tuned for that...good luck
ORIGINAL: 157db
And now the truth comes out.
Was more than a month ago, figured it was a non-issue considering the problem went away when I changed the fuel filter and I thought the guys putting my exhaust in knew wtf they were doing. Read the whole statement.
ORIGINAL: EXHAUST INSTALLERS
Hey, these wires look a little tight, ah **** it... these cables are strong enough to withstand anything... I'm sure they'll be alright...
I wonder who's wrastling tonight on WWE raw...
ORIGINAL: 157db
Do ya have any DTCs set?
Some have had to been set with the way you
are describing it to run.
Maybe you got the ever elusive 91 or 87 octane
fuel as some stations have been known to put
91 or 87 into their 93 tank by mistake or on purpose.
Do you think if this happened (human error) that
they would pump the mixed gas out and start all over?
I think not, they will just sell it as 93until its gone.
Have you checked the fuel in your tank for the octane
level before putting all those fuel system seal destroying
additives in there? Water is more viscous that fuel and
too much water thru the injectors and its bad news.
Drain the tank and get some proven 92 in there and see
what happens then.
what happens then.
I ended up going through the whole tank down to about a gallon and a half left and put in about a 1/2 tank of some good 93 from a Shell I found just in case I have to get the fuel pump out on Thursday after cleaning the MAF... So far after driving from the station and around for about 30 miles no change in driveability so it's not the gas I don't think...
Never saw crimps in my fuel lines, would you rule out a fuel rail obstruction? ****, I may end up changing the plugs, rail, pump and injectors after this just to be sure...
Cleaned the MAF, no change. Gonna put it on the lift tomorrow morning and get the hicks that changed the exhaust to do some O2 sensor checking.
At the very least they'll be able to tell me their ideas, and no charge...
KingRando
10-02-2015 08:06 AM
