Odd Problem
Old Apr 26, 2008 | 07:07 PM
BoilerBoy's Avatar
BoilerBoy
Default Odd Problem
My right hand turn signal is blinking twice as fast as my left hand one. It did it the other day and then I drove it again and it was back to normal, but today it is doing it again.
Any ideas? Anyone else having this problem?
Old Apr 26, 2008 | 07:14 PM
rmssch89's Avatar
rmssch89
Default RE: Odd Problem
Possibly one of your turn signal bulbs going dead.
Old Apr 26, 2008 | 07:18 PM
Legion5's Avatar
Legion5
Read your owners manual.
Old Apr 26, 2008 | 07:36 PM
jbspeed's Avatar
jbspeed
+1
Old Apr 26, 2008 | 07:38 PM
mx07gt's Avatar
mx07gt
check for moisture in your passenger side floor carpet, right where the carpet meets the plastic on the fender side....
might be the water leakage problem...
Old Apr 26, 2008 | 07:44 PM
eve's Avatar
eve
One of your turn signal bulbs on that side is blown
R.T.F.M.
Old Apr 26, 2008 | 07:57 PM
BoilerBoy's Avatar
BoilerBoy
I didn't get an owners manual with it.
Old Apr 26, 2008 | 08:32 PM
Wit05Vert's Avatar
Wit05Vert
Had the same thing a week ago on mine - you've got a brake light or turn signal bulb out on that side.
Mike
Old Apr 26, 2008 | 08:35 PM
boochy's Avatar
boochy
CSMG Moderator
Sounds like the fuel pump.
Old Apr 26, 2008 | 08:37 PM
sw07gt's Avatar
sw07gt
ORIGINAL: boochy
Erroneous its because a loose bolt has gotten into your continum transfuctioner causing a malfunction in the flux capictator which cause you left soleniod to go causing the increased blinking speed. Its ruined.
