need more o2 sensor trouble code help
Old Apr 27, 2008 | 04:07 PM
rojizostang's Avatar
rojizostang
Default need more o2 sensor trouble code help
okay, i thought i was finished asking questions about this, but i guess not. i keep getting the cel's. i check the codes, now i'm getting p0153, p0133, and p1000. i know what the codes stand for, slow o2 sensor response, but what's the next step? it seems weird i'd get two bad sensors at virtually the same time. i probably ran the off road x for 6 months without getting a code. now probably a month after installing shorty headers i keep getting codes...the positions of the sensors are virutally the same.
is my only option to put the stock h pipe, air kit and original tune back in and take it to a dealer for warranty work?
any help or advice would be appreciated, thanks.
Old Apr 27, 2008 | 04:49 PM
mustard05's Avatar
mustard05
Default RE: need more o2 sensor trouble code help
have you gotten a tune since the headers, did you installl the headers yourself or a shop, do you have a leak and what brand headers
Old Apr 27, 2008 | 05:32 PM
rojizostang
frpp shorties, definitely no leak. the only tune is the diablosport airaid tune with insert removed. all i have done is disable the catalyst temp sensors and adjust for tire size. headers were installed by a shop.
Old Apr 27, 2008 | 06:25 PM
hammeron's Avatar
hammeron
rojizo, have you considered getting
a custom tune (for your mods).
if you have no exhaust leaks, then the
tune just might be the problem, as
howarmat and mustang both suspect
Old Apr 27, 2008 | 08:40 PM
rojizostang
ORIGINAL: hammeron
I'll talk to PSI tomorrow and see what they say. perhaps the first step would be to put it on the dyno and see what it's doing along with the a/f ratio check.
really, thanks. i appreciate it.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
