Shifting into Reverse trouble (Automatic)
Old May 4, 2008 | 07:36 PM
imnotmy77stang's Avatar
imnotmy77stang
Default Shifting into Reverse trouble (Automatic)
Twice in the past few weeks i have went to shift into reverse and it just didnt quite feel like it went into gear even though it was right where it should be. when i went to touch the gas it revved slightly then BANGED into reverse pretty hard. the first time i thought it was a fluke, but now that it happened again im starting to wonder WTF is going on.
im bringing the car to ford this week for a little seat release lever replacing, and possibly getting the foam replaced that goes under the dash up by the windsheild because you can see it - i want them to address the trans issue while im there but i highly highly doubt i will be able to duplicate this problem while im there.
if anyone else has experienced this please let me know, some sort of answer would help troubleshoot this when i go. maybe shifter linkage out of adjustment? if so wouldnt other gears like drive or park not wanna go in properly?!?!?!
Old May 4, 2008 | 07:40 PM
brendend's Avatar
brendend
Default RE: Shifting into Reverse trouble (Automatic)
mine did it one time.....
Old May 4, 2008 | 08:23 PM
SemperFi789's Avatar
SemperFi789
ive experieced it several times, when it happens it seems as if i dont allow the trans a chance to switch (i press the gas too fast) at least thats what i have noticed
Old May 4, 2008 | 08:55 PM
imnotmy77stang
it definately had a chance to shift, like after 5 seconds and im like WTF then i shift to park and back to reverse and its still not right - then i tap gas and CLUNK it goes into R. weird though, cause its only happened twice and each time was weeks apart.
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
ChampInSD
Oct 2, 2015 04:55 AM
wraith777
Sep 28, 2015 10:49 AM
