Suspension NUT & BOLT Part Numbers...
There was a thread created some time ago with a list of all of the rear suspension replacement bolt & nut part numbers for the GT (e.g., LCAs, Pan hard rod/brace and rear sway bar).
Can someone please send methat link or better yet...have the part numbers available for me?
I really appreciate it - thanks.
RE: Suspension NUT & BOLT Part Numbers...
http://iihs.net/fsm/?dir=65
Shock Absorber upper nut30 ft-Lbs
Shock Absorber lower bolt85 ft-Lbs
Panhard rod-to-body mount bolt129 ft-Lbs
Panhard rod-to-axle bolt129 ft-Lbs
Stabilizer bar link bolts85 ft-Lbs
Stabilizer bar bracket nuts52 ft-Lbs
Brake hose bracket bolt15 ft-Lbs
I don't know if this will be helpful, they are for 2005.
Front Suspension
Rear Suspension
I went to the dealer for some of the rear suspension bolts, I'll just say, they're REALLY proud of them. [>:]
Front Suspension
Rear Suspension
Thanks everyone - I have another question...
Below where it says "qty: 2"... does that mean that the 8 bolts/nuts will cover both LCAs or do I have to multiply everything below by two equaling 16 bolts/nuts???
Thanks!!
Lower Control Arms:
Front Bolt: W711504-S439 Qty: 2
Front Nut: W710089-S440 Qty: 2
Rear Bolt: W704888-S900 Qty: 2
Rear Nut: W704991-S900 Qty: 2
Thanks!!
Lower Control Arms:
That is my thread (probably the only thread online anywhere of mine that gets consistantly referred to).
But the Qty. 2 is for how many of that part number you need to do that job. So for LCAs to do both LCAs you need 2 of each part.
Good luck.
Good luck.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
musnicki
09-23-2015 07:11 AM
bolt, bolts, mustang, numbers, nut, part, replacment, s197, suspension, w704888s439, w704888s900, w711504s439
