Door Speakers?
Old May 10, 2008 | 11:27 PM
0NF1R's Avatar
0NF1R
Default Door Speakers?
i just got a new PIONEER AVH-P4000DVD and figured since im replacing the radio, i might as well replace the speakers as well...only thing is, i havent the slightest clue as to which size speakers to get, i just want them to be pioneer as well....all i want to replace are the two door speakers and the two back seat speakers....im not sure if we have tweeters, but if we did, i might replace those as well....any help here?
Old May 11, 2008 | 12:18 AM
Orion_240's Avatar
Orion_240
Default RE: Door Speakers?
Please scroll down to the bottom of this page
Look under Related Threads
Old May 11, 2008 | 07:58 AM
my06shaker's Avatar
my06shaker
Pioneer 6x8 fits perfectly. Easy install. While you're in there if you want to change out your interior door handles it would be the time to do it.
[IMG]local://upfiles/86175/1398E3C61E4B4BFDBBDE98755E204F88.jpg[/IMG]
[IMG]local://upfiles/86175/2428FBB426614B17BF9F170DACCC3FB9.jpg[/IMG]
[IMG]local://upfiles/86175/8096D2B9342D435BAD5CD8EC0A152215.jpg[/IMG]
Old May 11, 2008 | 08:03 AM
0NF1R's Avatar
0NF1R
what about the front door lower speakers and the rear seat speakers?
Old May 11, 2008 | 08:56 AM
imnotmy77stang's Avatar
imnotmy77stang
i heard 8's fit.... i'm curious as too how much power the shaker 500 puts to those speakers cause i have some 8's i'd like to try to fit in there
Old May 11, 2008 | 09:37 AM
my06shaker's Avatar
my06shaker
I have a convertible so my rear speakers come out different from yours. They will both take 6x8's in the rear seat area. The front subs bolt in from inside the door panels so don't try to pry them out. They will break. They take a specific voltage feed from the factory amps so I'm not sure what you would have to go to in order to satisfy what you're looking for. The factory subs satisfy my 50+ year old needs. The factory speakers were weak and had to go. The pioneers are three ways and sound great. I have a pioneer inno satellite radio integrated into the system and everything works well together.
Old May 11, 2008 | 05:57 PM
MartyMoose's Avatar
MartyMoose
ORIGINAL: my06shaker
Hey, what door handle is that and is the finish close the the stock satin?? Thanks!
I just replaced the door speakers today with Infinity 5x7's that had 6x8 tabs for 6x8 mounting. The regular mounting holes fit the door enclosure and I had to bend off the 6x8 tabs.
Old May 12, 2008 | 07:04 PM
0NF1R's Avatar
0NF1R
so i can go out there and buyfour 6" x 8" speakers and dont have to worry about them not fitting?...the only speakers i want to change right now are the regular ones...ill leave the tweeters and the subs in there for now....
Old May 12, 2008 | 07:14 PM
sp44's Avatar
sp44
go to crutchfield and check what 6x8's work, I think 5x7 is a better bet
Old May 12, 2008 | 07:18 PM
07ccdskaterv6's Avatar
07ccdskaterv6
yes im pretty sure the 6x8s will fit in the front i know that they will fit in the back and the 8" subs have to be the thin ones i thinnk they are by pioneer also
sweet roush onf1r
