need help real quick
Old Apr 24, 2005 | 03:55 PM
KandyMan's Avatar
KandyMan
Default need help real quick
went onto www.motegiracing.com website and found the wheels im dying for...thing is i go under 2005 mustang gt and it dont list the wheels...but if i do a 2004 mustang gt it has em....i know i should know this cuz i werk for a ford dealer...but arent sizes and offsets universal between them.....otherwise im scewed....i really like these rims...but for all you gear heads please help me...here are the specs on the wheels i want
Product Number: 21788165
Product Description: 18X10 TOUGE GBLK 5X4.5+30 GLOSSY BLK
Backside Spacing (in/mm): 6.625/168
Offset: 30 mm
Product Number: 21788965
Product Description: 18X9 TOUGE GBLK 5X4.5+12 GLOSSY BLK
Backside Spacing (in/mm): 5.5/140
Offset: 12 mm
like i said it says it fits 04 mustang gt's but it dont list em under 05 gt please help
Old Apr 24, 2005 | 04:28 PM
elmo771's Avatar
elmo771
Default RE: need help real quick
The offset is different for the 05 I believe it is 36mm
Old Apr 24, 2005 | 04:49 PM
showam1's Avatar
showam1
I ♥ Acer
Different backspacing is different backspacing, no way around it.
Some have used them, but I have read that this is hard on the bearings.
If it was for the 2005, It would be under the 2005 wheels.
Old Apr 24, 2005 | 04:57 PM
MobyDickDog's Avatar
MobyDickDog
The 2005 Ford Mustang GT has a +45mm Offset wheel from the factory. The allowable Offset is +19 to +65. A nice looking range is +30 to +45 Offset.
THIS ASSUMES you are still going to use an 8" wheel. All you had/have to do is measure the BackSpacing(BS) of the stock wheel. Then decide how much farther out you want your new wheel to stick out from your stock wheel. Subtract that from your stock backspacing. This is your new Backspacing that you will need on your new wheel. You might ask, what about OFFSET? If you have one you can caluculate the other. Remember back in High School that class that you thought was "useless and you will never use this stuff."
OFFSET = (OVERALL width - BS) / 2
Example: (9" - 5.75) / 2 = 1.625 " OFFSET
The OVERALL width on an 8" wheel is not 8". For example it might be 9" or 10" or 9.75".
American Racing Torq Thrust II will require a minimum BS of 5.5" on an 18 X 8 wheel.
I have gotten only 1 qoute in my area so far for AR Torq Thrust II Polished. $325 per wheel. 4 to 12 weeks.
Old Apr 24, 2005 | 05:04 PM
KandyMan's Avatar
KandyMan
so does that ean they will fit or not????????
Old Apr 24, 2005 | 05:18 PM
MobyDickDog
Based upon my posting. And my posting only. I would say NO. They will not fit. But,...................
Do you have quick access to a Discount Tire? If so, call them!!!
Now I should say that they will fit, but may not have the important look that you want. Just about anything with a 5 X 4.5 bolt pattern will fit, but it may not look good.
The +12mm OFFSET on the 18 X 9 wil really bring the wheel out of the wheel well.
My guess ta mut would be that the wheel will stick out about an inch from the stock 8" wheels.
Old Apr 24, 2005 | 05:54 PM
showam1's Avatar
showam1
I ♥ Acer
nobody is addressing the wheel bearing issue again!
read this and pay special attention to the "Note" under the offset section, this should not be overlooked! all you have to do is look at the bearing placemnet in the wheel and imagine a little leverage as you turn and think of the stress applied to the bearings
http://www.bentickner.com/tahoe/wheels.htm
Old Apr 24, 2005 | 06:48 PM
MobyDickDog
showam1
You are 100% correct!!!
In a nutshell if you draw an imaginary line from the center of the top spindle pivot to the center of the bottom spindle pivot and continue this line to the ground, it should coincide with the center of the tire footprint. If not, you WILL have stresses placed on bushings, bearings, and ball joints. THIS IS CALLED THE SCRUB RADIUS.
Of course, kids (and adults too) with lots of money don't really care about this stuff. Because they have money to repair the items that WILL cause problems in the future. The same holds true on the subject of lowering their cars. Some think I'll just add springs and I'll be set. There is more to it than that. I was told by someone on this forum that "ANYBODY" can do it, just take it to a mechanic. That summarizes it all right there. A lot of people do not understand what they are doing to there cars. Can it be done? Sure, but you better know/understand what you are gaining and what you are giving up.
Some here on this forum do not even know what a Panard bar is not alone what it does. However, they may be learning after they have already spent the $$$ on lowering their car. And that is part of tinkering and learning but at a cost.
That is what is scary about reading some of the things here on this forum. There are people doing things to there beautiful cars that they have no idea how they are affecting the engineering.
Anyway, it's still fun to talk about how cool your car looks though.[8D]
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
