shaker 500 stereo-night illumination
Old May 14, 2008 | 09:34 AM
alamobandit's Avatar
alamobandit
Default shaker 500 stereo-night illumination
We just bought an 05 Mustang. It has the Shaker 500 sound system. 6 disc in dash changer.
My question is this: at night, when you turn the headlights on, the buttons do not illuminate. Only the digital display is visible. Are the buttons supposed to be lighted or are they not?
I find it hard to believe that they wouldn't be but I guess it may be the case. Does anybody know if the stereo buttons on this system should be illuminated?
tkx
Old May 14, 2008 | 09:35 AM
d4rb's Avatar
d4rb
Default RE: shaker 500 stereo-night illumination
Yes, they should illuminate.
Old May 14, 2008 | 09:44 AM
alamobandit
any advice on what might be cause of it not working? I haven't check the fuses yet.
tkx
Old May 14, 2008 | 10:41 AM
Johnboy7701's Avatar
Johnboy7701
Fuses maybe but the shaker itself is working... might be the player itself....
Old May 14, 2008 | 10:54 AM
Kaisoboy's Avatar
Kaisoboy
ORIGINAL: alamobandit
tkx
I also just bought a 05 GT with the Shaker 500 and the buttons also do not luminate at night with the lights turned on. The HU works fine just does not luminate. I talked to my dealer and they said to book it in and they would look at it and 10 to 1 would replace the HU under warranty. If anyone does know of an easier fix I'm all ears.
Subscribed.
Old May 14, 2008 | 10:56 AM
Z06 Killer's Avatar
Z06 Killer
If the HU has ever been swapped out with an aftermarket then maybe the illumination wire was not reconnected correctly
Old May 14, 2008 | 11:15 AM
Gone2's Avatar
Gone2
Mine did the same thing when I bought it. The dealer hooked it to the computer and changed a PCM setting. It was programmed wrong from the factory and they just had to change it; nothing was broken.
From your name I assume you're in San Antonio. I took my car to Jennings Anderson Ford in Boerne for them to reset it. They already knew of that type of problem.
Old May 14, 2008 | 11:17 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Z06 Killer
There is no illumination wire on the stock radio and the
stang wiring does not have one persay. Illumination is
controlled by the can buss data network that stangs have.
I would be checking for the water leak near the SJB.
Or the as built data could be wrong or corrupted.
You cant just go swappin OEM radios unless the stangs
that the radios came out of have the same build data.
Old May 14, 2008 | 11:32 AM
wingman75's Avatar
wingman75
Yes they should be illuminated. Mine work fine on my 500.
Old May 14, 2008 | 01:50 PM
2cokeman's Avatar
2cokeman
Mine do too!
