Another D3 question.
Old May 21, 2008 | 05:01 PM
rad_rob's Avatar
rad_rob
Default Another D3 question.
So Im posting this in here since it gets way more traffic. I just purchased my AVIC D3 and today picked up the dash kit and harness. I got the dash kit from American International as well as the harness. SOOOO much nicer than the metra junk. Anyways, the harness came with a resister and says to solder inline with the remote wire to keep from popping. Am I correct in assuming that does the same thing as the 5v voltage regulator that everyone was using?
Old May 21, 2008 | 05:12 PM
ThumperMX113's Avatar
ThumperMX113
Default RE: Another D3 question.
Correct.
Old May 21, 2008 | 05:19 PM
rad_rob's Avatar
rad_rob
Awesome. I also remember seeing somewhere a while back about wiring up the dimmer for when you turn on the headlights over behind the headlight switch, but theres an orange/white wire for the dimmer right on both harnesses. Why were people doing it the other way?
Old May 21, 2008 | 05:23 PM
ThumperMX113
I have no idea. I never hook up the dimmer. I just use the dimmer on the unit itself.
Old May 21, 2008 | 05:47 PM
rad_rob's Avatar
rad_rob
Ok cool, Ill probably just end up doing that.
Old May 22, 2008 | 05:35 AM
EricM's Avatar
EricM
ORIGINAL: xROBxCOREx
The wire from the car is some non-standard voltage that only seems to work with the factory radio.
Old May 22, 2008 | 11:30 AM
rad_rob's Avatar
rad_rob
^Oh ok. Ill probably just end up not worrying about it. I dont know how bright it is at night, but if it bugs me, then Ill wire it up.
Old May 22, 2008 | 11:53 AM
d4rb's Avatar
d4rb
It's very bright at night. I only let it go for 1 night before running that wire for the dimmer. It can be kind of distracting.
Old May 22, 2008 | 12:35 PM
ThumperMX113
... you can dim the unit within the unit itself without that wire being connected.
Old May 22, 2008 | 03:20 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Rob, where did you get the American brand kit and harness? Im getting the Kenwood DNX5120 and I want to install myself.
