Gauges
Old May 23, 2008 | 03:32 PM
jerseyblood's Avatar
jerseyblood
Default Gauges
I have a Whipple HO kit on its way and was wondering which gauges are the most important to get. Obviously I want to get the boost gauge but what other gauge should I get at this point and why? I have an SOS pillar on its way and its the double gauge one.
Old May 23, 2008 | 03:34 PM
onederful100's Avatar
onederful100
Default RE: Gauges
if you get 1 more gauge, make it a wide band a/f, for safety making sure the a/f ratio is where it should be. the boost you can have mechanical.
Old May 23, 2008 | 03:46 PM
cobra443's Avatar
cobra443
Default RE: Gauges
Im getting Boost/Vac, Fuel Pressure, and Air/Fuel Ratio. You could always put one in your air vent or between the 2 middle ones.
Old May 23, 2008 | 05:28 PM
MustangBatman1's Avatar
MustangBatman1
Default RE: Gauges
I would say wideband a/f
Old May 23, 2008 | 05:38 PM
cobra443's Avatar
cobra443
Default RE: Gauges
Sorry to steal the thread but what is the best place (cheapest) for guages.
Old May 23, 2008 | 05:54 PM
onederful100
Default RE: Gauges
i got mine from jegs but i got the SOS pilarpod form lethal, i compared gauges to lethal, and it just depends what style/brand, i ended up w/ z series autometer gauges (i wanted some plain black gauges), which lethal didnt have. in general, i dont think one site is cheaper than another.
Old May 23, 2008 | 06:35 PM
slvrstang2007's Avatar
slvrstang2007
Default RE: Gauges
Nope I'l looked around for gauges too and they all seemed to be the same prices for the most part. I ended up getting boodst A/F ratio and fuel gauges full swept electric (autometer full swept electric) from lethal. If you do end up getting A/F gauges make sure it actually tells you what it's at. None of those gauges that only tell you if your rich or lean for 60 bucks, you need to weld in a bung and plug in the sensor in your exhaust, or else it's basically a light show and wont be very useful.
Old May 23, 2008 | 06:52 PM
cobra443's Avatar
cobra443
Default RE: Gauges
ORIGINAL: slvrstang2007
Those are quite expensive. Couldnt you just judge your air/fuel ratio by your fuel pressure? I might be totally wrong (trying to learn so dont get all worked up if I'm incorrect)
Old May 23, 2008 | 07:10 PM
onederful100
Default RE: Gauges
the WB a/f gauge will be a lot more accurate than going w/ the fuel pressure alone. the fuel pressure gauge will tell you how the fuel pump is working, but the WB a/f will tell you what the ratio between air and fuel, most importantly at WOT. i believe the WB a/f is the most important gauge to get for safety purpose in a FI setup and for tuning, if you are going to do datalogging. even if you tune on a dyno the bung welded into the exhaust will be more accurate than putting a sniffer at the end of the exaust. IMO if you got money for a SC, a few hundred bucks more is not that much to keep an eye on your investment. yes, those gauges are expensive, but it eases my mind knowing everything is working correctly.
Old May 23, 2008 | 07:15 PM
cobra443's Avatar
cobra443
Default RE: Gauges
ORIGINAL: onederful100
Your absolutely right. Another question though, is it ok to use the mechanical boost/vac gauge or should I go electric with that as well. Im getting the electric fuel pressure guage trying to save some money for some Mickeys.
