Replacing my plugs with Champion 7989's (mid upgrade question!!)
I'm mid-process of swapping my plugs out with Champion 7989's. I've got one head done and whenreplacing the coil packs I don't hear the distinguishable "snap" that I'm used to when replacing plug wires (or coil packs in this instance). Should you hear a snap when these seat???
RE: Replacing my plugs with Champion 7989's (mid upgrade question!!)
dear god champion plugs are even worse the bosch
how are the coils sitting on the plug are they tight or does it feel like there not together
If I weren't mid stream upgrading my plugs I'd be more easy going, but these don't seem to seat well onto the plugs for some reason.
I push the coil packs back down onto the plugs to where the cp's bolt up but never get an affirmative "snap"????
As easy as this side came out and after seeing that the plugs are in EXCELLENT shape, I'm wondering if I should even worry with the other side.....
ORIGINAL: mustangman02232
There is no audible 'snap' when setting the COPs in place. Just feels kinda like a wet noodle. As long as you have almost no space between the COP and its bolt up hole, your good to go.
Thanks. they're all in now and my throttle is snappier than ever!! Taking a test drive and will let you guys know the diff....
