Hurst shifter and Rattling noise
Old Jun 7, 2008 | 09:40 PM
Vegasstang08's Avatar
Vegasstang08
Default Hurst shifter and Rattling noise
I installed a Hurst shifter (Ford Racing) several months ago, and lately I am getting a rattle at higher rpms if I am not holding the shifter, any clues? Of course this all happened as soon as the temperature stated to rise here in Vegas. I have already gone through and check all the bolts to make sure they are tight, It is driving me nuts, could there being something wrong in the traney and it is resigning through the shifter?
Please help!
Old Jun 7, 2008 | 11:12 PM
GrayPony's Avatar
GrayPony
Default RE: Hurst shifter and Rattling noise
Hurst suggests that you install thin rubber washers between the chrome stick and base and loctite the screws.
Old Jun 7, 2008 | 11:29 PM
boomer123's Avatar
boomer123
same thing happens to me....but i guess ive just learned to hold it haha
Vegasstang08
Where did you see the posting about Hurst suggesting thin rubber washers? and do you know what size they might be. I have loctited the bolts and it still rattles, so I will try the washers, and hopefully it will workers. thanks.
P.s. never use red loctite, I broke a wrench try to lossen the bolts...
Old Jun 7, 2008 | 11:33 PM
Vegasstang08
boomer123 what year is yours? and how long have you had your shifter?
Old Jun 7, 2008 | 11:45 PM
Vegasstang08
Just found this posting (see below), i am going to try this tomorrow and let you know how it works.
http://www.allfordmustangs.com/forum...ion-issue.html
Old Jun 8, 2008 | 01:33 AM
boomer123's Avatar
boomer123
i have an 05 gt, and ive had my shifter since mid april maybe?
Old Jun 8, 2008 | 02:35 AM
rford426's Avatar
rford426
ive had my shifter for abnout 5 months now and mine also raddles around 4200rpm
Old Jun 8, 2008 | 06:44 AM
BADH0RSE's Avatar
BADH0RSE
Hello all,
I also installed the Billet Hurst shifter and experienced the same vibration issue. After some though, I replaced the rear bushing with the OEM and the problem went away. Furhtermore, since replacing the bushing I have not noticed any difference in shifting performance which is good. The washer theory is interesting.
Badh0rse
[IMG]local://upfiles/86831/75D486BDFDEB452492BD95E9A83C3EBE.jpg[/IMG]
Old Jun 8, 2008 | 07:28 AM
CorruptedDemon60's Avatar
CorruptedDemon60
Almost a year with mine and i dont got a noise. I guess I'm lucky.
