a/c not working
Old Jun 9, 2008 | 12:19 PM
StickShifty's Avatar
StickShifty
Default a/c not working
went to turn on the A/C for the first time last week, and it doesnt work. i let it run for a good 1/2 hour with the A/C blasting, and still nothing.
i remember there was a recall for some 2008s. was it for the A/C by chance??
guess i have to return it to stock, and take it back to the dealer.[]
anyone else have to same problem, or had??
Old Jun 9, 2008 | 12:33 PM
owero01's Avatar
owero01
Default RE: a/c not working
Take it to the dealer and have them check it. You don't have to return it to stock unless you did something that involves changes to the compressor. You should have them check for a leak in the A/C unit.
Old Jun 9, 2008 | 12:50 PM
StickShifty
it will take me 15 mins to take my CAI out and retune. when i turn the A/C on nothings happens, the compressor doesnt even run.
Old Jun 9, 2008 | 12:52 PM
owero01's Avatar
owero01
That may be a fuse issue. I don't know which one controls the A/C.
Old Jun 9, 2008 | 12:54 PM
Z06 Killer's Avatar
Z06 Killer
Sounds like there may have been a leak in the system, when it runs low on refigerant it will not engage the electric clutch on the copressor. Of course it could be an electrical issue as well, or a bad sensor or even maybe an unplugged harness. ( double check all connections before going to the dealer as most wont cover it if you unpluged something)
Old Jun 9, 2008 | 01:01 PM
SumterBoy's Avatar
SumterBoy
Just take it to the dealer, i'm pretty sure its still under warranty seeing as how its an 08.
Old Jun 9, 2008 | 01:08 PM
grampa_stang's Avatar
grampa_stang
Before you take it in. Just going to state this, no dis-respect intended. When you turn the dial
to the "cold" position and then kick on the fan, if the A/C does NOT automatically engage, try
pressing the A/C button (it will light up orange). Is yours lighting up orange?
Old Jun 9, 2008 | 01:18 PM
swata's Avatar
swata
When I got mine it needed a re-charge... You would think a new ride would be good to go. They should be able to get you handled at the dealer.. +1
Old Jun 9, 2008 | 03:59 PM
WhiteHorse94's Avatar
WhiteHorse94
I don't think theres been a single day whenmy a/c WASN'T on.
Itz hot outside, lol
Old Jun 9, 2008 | 06:30 PM
redfireshaker06's Avatar
redfireshaker06
Before I even left the lot for the test drive I had no AC. The seal in the compressor was bad. I guess theres a TSB on that.
