Sponsored by:
Sponsored by:
Stock Popping Suspension
Old 04-27-2005, 03:14 PM
Shodan01
Shodan01's Avatar
Default Stock Popping Suspension
Does anybody have an issue with a popping suspension???
I have not done anything to the suspension yet, but worried about occasional popping sound...
SC
Shodan01 is offline
Old 04-27-2005, 03:17 PM
td1320
td1320's Avatar
Default RE: Stock Popping Suspension
ORIGINAL: Shodan01
SC
There is a TSB out that tells the dealer not to fix it until Ford has a correct repair for it. Same as the defroster flapper not shutting off when you go to floor only.
td1320 is offline
Old 04-27-2005, 06:05 PM
Scottsat
Scottsat's Avatar
per my "Friendly Ford Service Rep"
18461 2005 MUSTANG - POPPING NOISE - FRONT OF VEHICLE ON TURNS
2005 MUSTANG VEHICLES MAY EXHIBIT A POPPING NOISE COMING FROM THE FRONT OF THE VEHICLE IN TURNS. VERIFY THAT NOISE IS COMING FROM THE STRUT BEARING OR SPRING WITH CHASSIS EARS. ENGINEERING IS CURRENTLY INVESTIGATING. NO REPAIRS SHOULD BE ATTEMPTED AT THIS TIME. MONITOR OASIS FOR UPDATES.
EFFECTIVE DATE: 03/10/2005
Wait and see......
Later,
[IMG]local://upfiles/13237/6DA260720051476592A133B81855700C.jpg[/IMG]
Scottsat is offline
Old 04-28-2005, 10:01 PM
Casper98GT
I ♥ Acer
Casper98GT's Avatar
Hmmm.... This is per a FORD specialist tech (thats me by the way. lol )
TSB
05-9-11 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
Publication Date: April 27, 2005
FORD: 2005 Mustang
ISSUE:
Some 2005 Mustang vehicles built before 4/8/2005 may exhibit an intermittent popping noise from the front of the vehicle while turning left or right. The noise will typically occur during low speed maneuvers and may occur multiple times while turning.
ACTION:
On both sides of the vehicle, install a revised upper strut bearing assembly. If the vehicle was built before February, 2005 it may also be necessary to install a lower spring seat isolator if one is not already present. Refer to the following Service Procedure.
Casper98GT is offline
Old 04-29-2005, 12:54 AM
Scottsat
Scottsat's Avatar
ORIGINAL: Casper98GT
TSB
FORD: 2005 Mustang
ISSUE:
ACTION:
Cool, thank you for the information Casper......
I'm not worthy........[sm=hail.gif].
Thanks Dude,
[IMG]local://upfiles/13237/1B48FD44D59544E4B5115EAA84846E3B.jpg[/IMG]
Scottsat is offline
StalkerGT
09-25-2015 02:41 PM
GimpyHSHS
09-18-2015 12:27 PM
09-08-2015 11:50 AM
RWHEELS
09-05-2015 03:42 PM
09-01-2015 08:16 PM
Quick Reply: Stock Popping Suspension
