Line Locs
Old Jun 10, 2008 | 06:02 PM
Stangbanger3v's Avatar
Stangbanger3v
Default Line Locs
has ne one put on line locs on the s197 how hard was the install? which is the best
Old Jun 10, 2008 | 06:24 PM
surfbum7190's Avatar
surfbum7190
Default RE: Line Locs
i put line locks on a camaro. they are kind of boring cause you just sit there and burn em. id rather walk my burnouts with my brake and swing the back end. but the install was cake..
i would say not to do this though
Old Jun 10, 2008 | 07:45 PM
281GT's Avatar
281GT
I used a kit from Brenspeed. The brand name was SLP. Price was very reasonable and they have free shipping to the continental U.S. The hardest part was removing the old brake line. The line that connects the front brake system from the master cylinder to the ABS unit has to be removed. It was necessary to cut it to remove it.
The rest of the job went smoothly except for one thing. Where the solenoid mounts on the side of the strut tower that faces the side of the engine. I had to get a right angle drill to drill the mounting holes as there is NO way to do it otherwise.
I've had line locks in other vehicles and I really like them. It makes it possible to do a burnout without tearing up your rear brakes.
It also is just a lot easier to do your burn out with the line lock. You don't have to worry about applying just the right amount of brake pressure while applying the throttle and using the clutch all at the same time.
Just hit the brake, throw your line lock switch and do your burnout and hit the switch again.
Old Jun 10, 2008 | 07:50 PM
28HopUp's Avatar
28HopUp
MF Administrator
Shameless plug -
https://mustangforums.com/m_4725249/tm.htm
Old Jun 10, 2008 | 07:54 PM
DarkFireGT's Avatar
DarkFireGT
Here's my write-up on the PMP Jegs kit. It's not difficult, just a bit time consuming. But it's quite easy.
http://www.stangnet.com/Tech-Article...ll-080225.html
Old Jun 10, 2008 | 11:08 PM
PLstang's Avatar
PLstang
I have the SLp kit. As was mentioned works well and not hard to install.
Old Jun 11, 2008 | 09:17 AM
Ruffnuts's Avatar
Ruffnuts
I also have the slp kit and to get around the drilling issue I just zip tide mine. Since it never moves and isnt near any heat I figured this would work fine and it does.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
