New Engine?
Old Jun 14, 2008 | 10:19 PM
Caution's Avatar
Caution
Default RE: New Engine?
Old Jun 15, 2008 | 11:16 AM
Buckman's Avatar
Buckman
I've got a 2007 4.0 v6 and I want to drop in a new engine.Prefferably a 5.4, but most likely the more affordable 4.6.Can I go back any later than an 05 engine? Orwill some of the older 4.6's bolt on with minimal trouble?
Yes, it can be done, and as posted above it will take a good chunk of change.
If you are looking to drop in a 5.4, then a 5.4 3v is a great way to go if you don't want to spend the money on a GT500 engine. You can pick up the 5.4 3v fairly cheaply, but you are also talking about new trans, wiring harness/comp and a ton of peripheral parts that add up fast.
Your best bet is to talk to a performance shop that knows what they are doing and partner up with them to help map the way.
A rough price to do a 5.4 3v is 15k, but obviously a lot depends on what you spend on the engine and trans.
Old Jun 15, 2008 | 11:30 AM
kenthicken's Avatar
kenthicken
It can be done... but buying a GT outright would be less expensive if you want to go the 4.6 route.
Old Jun 15, 2008 | 11:52 AM
conor1148's Avatar
conor1148
heck, with all the money you would be spending you could ALMOST buy a used gt500 if you sold your 6er and got a good bit for it
Old Jun 15, 2008 | 12:30 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Well money aside, I really approve about engine swaps successfully done...
Folks like buckman are the sh#t. Make a sixer go fast and then put a totally different set-up.
Nothing conventional.
I like that.
Old Jun 15, 2008 | 07:54 PM
ryanralston07's Avatar
ryanralston07
What about getting a built 4.6 3v like the one that livernois offers and then throwin on the ST Motorsport's whipple supercharger kit that uses the 3.4L whipple that can be used on the GT500? That'd be a lot cheaper and you could still have a CRAZY fast car and those are rated up to 1,000hp...if you want more then you could switch out to another block on down the road...
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
