Braking HELP
Old Jun 16, 2008 | 10:53 PM
lrgnation's Avatar
lrgnation
Default Braking HELP
Okay I will be needing to get the gt caliper brackets for my v6 because I am going to be changing my brake system to the following. So if you have the part number or let me know the best place to get the brackets that would be great.
DBA 4000 series rotors
HPS -performance street pads
goodridge braided brakeline kit
ate brake fluid(Will the dot4 work?)
I am street driver but i drive hard and i have 20" wheels so i am in need of stopping force. If anyone used any of these items please chime in and let me know how it worked out.
BTW: SEARCH WONT WORK.
Old Jun 17, 2008 | 11:10 AM
Argonaut's Avatar
Argonaut
Default RE: Braking HELP
I have the goodrich lines and use ATE SuperBlue - both are excellent.
Haven't used the HPS pads for the street yet, still wearing out the stock pads (do use Hawk track pads for HPDE events though). I will switch to HPS for street in the future.
Don't know about the rotors or brackets.
Old Jun 17, 2008 | 11:25 AM
Red_Stallion's Avatar
Red_Stallion
Not meaning to hijack the thread, but I am in the process of upgrading my braking system too and actually just ordered the HPS pads....
just as a general question, though, is the fade we experience on the stock system caused more by the pads or the rotors?
Old Jun 17, 2008 | 11:46 AM
lrgnation's Avatar
lrgnation
ORIGINAL: Red_Stallion
its the combination of both. As the system heats up its causing the rotors to glaze up and the pads dont be come as effective with the build up on the rotor which is why rotors warp sometimes. Also once the system heats up and the fluid boils, the integrity of the fluid has changed so its not as effective.
Old Jun 17, 2008 | 06:47 PM
Red_Stallion
So if I swap out my fluid to some DOT5 and go with new pads, that should provide me a significant (and economical) improvement over the stock system?
Old Jun 17, 2008 | 09:06 PM
Argonaut's Avatar
Argonaut
Read This: https://mustangforums.com/m_5098243/tm.htm. What are you doing that is causing brake fade?
Old Jun 17, 2008 | 11:30 PM
lrgnation's Avatar
lrgnation
okay for sure. So now all i need is about $1000 and I think i'll stick with the what I listed. I'll probably try to install koni's at the same time. So I hope that I am going to pick up a lot that I have been lacking in this car.
Old Jun 18, 2008 | 12:00 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Do you need the GT calipers and rotors? Im switching to a big brake system soon.
Old Jun 18, 2008 | 01:37 AM
lrgnation's Avatar
lrgnation
ORIGINAL: MELLOWYELLOW06
I just need the bracket to hold the stock calipers.
Old Jun 18, 2008 | 10:18 AM
157dB's Avatar
157dB
Cut & Paste Expert
I also need the brackets.
PM me if you have the GT caliper Brackets just laying around collecting dust.
You need 2 caliper brackets part #6R3Z-2B134-B, the same left and right.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
