Lowering just the rear
Old Jun 18, 2008 | 08:45 AM
ryanralston07's Avatar
ryanralston07
Default Lowering just the rear
Will I need an adjustable panhard bar? I'm going with the roush rear springs and I already have an adjustable UCA and fixed LCA...
Old Jun 18, 2008 | 08:48 AM
5SPD07GT's Avatar
5SPD07GT
Official Site Sponsor
Default RE: Lowering just the rear
you wont need anything at all. i have the roush rear springs only and you'll be fine.
Old Jun 18, 2008 | 08:51 AM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
+1 Roush springs
Old Jun 18, 2008 | 10:02 AM
157dB's Avatar
157dB
Cut & Paste Expert
No adj panhard needed. Unless you are **** or have oversized
tires and they just clear the fenders before the 3/4" drop.
44" long panhard bar at 2 degrees to the axle tubes OEM.
Now lower it 3/4" and do the math. Its less than 0.100
thousands of an inch shift to the drivers side.
Math is your friend.
Old Jun 18, 2008 | 10:53 PM
ryanralston07
Thanks for the information guys. Will I need Relocation Brackets for the LCA's? I have an adjustable UCA...
Old Jun 18, 2008 | 11:04 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
for that drop and having an adj UCA.....IMO no you will not need the relocation brackets. Check your pinion angle before and after to be sure but TacoBill did not need the brackets for a 1.25 inch drop.
Old Jun 18, 2008 | 11:14 PM
ryanralston07
Thanks mygt500...so leveling out the car by lowering the rear...would I get any more performance advantages?
Old Jun 19, 2008 | 11:29 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: ryanralston07
Yes, its kinda like LCA relocation brackets but without the brackets.
You bring the front LCA mounts closer to the ground than the rear
LCA mounts on the axle tubes with the installation of lowering springs.
The difference is slight but there is a difference and its for the better.
The axle is now pushing the vehicle more forward instead of upwards
as with the OEM rear ride height.
mtgldr
Feb 3, 2024 09:00 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
TfcCDR
Sep 14, 2015 12:08 PM
Dragonus18
Sep 9, 2015 01:21 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
