Trouble code - Need Help!
Old Jun 22, 2008 | 06:13 PM
ptaka69's Avatar
ptaka69
Default Trouble code - Need Help!
Hello.....I was changing out my valve covers( to chrome) and after that Ithen used my SCT X3 that I bought to program in my Mustang my custom tunes. I got the "check engine light" and when I read the code it said P0020. I cleared it with mySCT but it comes back again.Can anybody tell me what that means & how to fix this problem. Thanks:-)
Alan (Mustang GT 2005)
Old Jun 22, 2008 | 06:16 PM
downriverT's Avatar
downriverT
Default RE: Trouble code - Need Help!
A camshaft pos act bank2
sailing220's Avatar
sailing220
Are you sure it was P0020 and not P0200?
P0200 is an injector circuit malfunction. When replacing the valve covers you could have damaged/moved something that messed your injector circuit up.
Old Jun 22, 2008 | 06:23 PM
mlcrycc's Avatar
mlcrycc
Assuming your first listed code is correct, did you remember to plug the cam sensor or sensors back in after replacing the cam covers??
Old Jun 23, 2008 | 10:09 AM
ptaka69's Avatar
ptaka69
The code did say P0020. I will recheck the cables but if the cables are all hook up any suggestions on how to correct the problem? Is the cam sensor the one above the valve cover or on the side of the block? Thanks:-)
Alan
Old Jun 23, 2008 | 03:48 PM
ptaka69's Avatar
ptaka69
Can anyone help on the trouble code P0020? Which side is the cam sensor having the problem, and how to fix it. Thanks
Alan
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
