Tech question need help !!!
Old Jun 23, 2008 | 10:11 AM
lukas77's Avatar
lukas77
Default Tech question need help !!!
I'M A PROUD OWNER OF 07 GT. EVER SINCE i INSTALLED THE BBK THROTTLE BODY I HAVE BEEN HAVING TROUBLE WITH THE CARS RPM. ONCE U REV IT UP PAST 4 GRAND THE RPM WILL STAY THERE FOR AT LEAST 5 SECONDS AFTER U GET UR FOOT OFF THE PEDAL AND THEN IT WILL SLOWLY START DROPING. SOUNDS LIKE CRAP AND IT PISSES ME OFF. IF ANYONE ELSE HAD A SIMILAR PROBLEM PLZ LET ME KNOW HOW TO FIX IT !!! THANKS A LOT GUYS FOR ANY SUGGESTIONS AND HELP U MIGHT HAVE FOR ME !!!
Old Jun 23, 2008 | 10:15 AM
2L8IWIN's Avatar
2L8IWIN
Default RE: Tech question need help !!!
Wish I could help you out. I have never heard one good thing about replacing the TB on these cars....seems like it always gives people problems. I'm not touching mine.
Old Jun 23, 2008 | 10:20 AM
lukas77's Avatar
lukas77
THE ONLY GOOD THING ABOUT IT IT SOUNDS AWESOME CUZ IT WHISTLES LIKE A TURBO AND IT GIVES U THAT EXTRA KICK WHEN TOUCH THAT PEDAL !!!
Old Jun 23, 2008 | 11:22 AM
zkiller's Avatar
zkiller
What is the point of installing a BBK throttle body? There is no power gain and it makes your car run like crap. If you had researched this first you would have found that everybody who installed one regretted it.
Old Jun 23, 2008 | 11:29 AM
billyjo's Avatar
billyjo
the spring inside that you switched out is your problem. when you moved it from one tb to the other tb it sounds like you didnt adjust and prime it right. so the spring isnt doing what it should. I agree with above that there no after market tb that is consistent. so i would advise to go back to stock or look up the proper spring pressure and then reattach.
Old Jun 23, 2008 | 11:31 AM
Joolander's Avatar
Joolander
Lord High Protector
please stop yelling, and please change your thread title to something less vague
Old Jun 23, 2008 | 11:54 AM
lukas77's Avatar
lukas77
I am determined to make this TB work. And yes I did research it before I bought it but I went against my better judgement so there I said it !!!
Old Jun 23, 2008 | 12:13 PM
05Saleen#243's Avatar
05Saleen#243
I bought the GMS one and it did the same exact thing. There's no point to getting one unless you're F/I, and then you should probably upgrade to the GT500 TB.
Old Jun 23, 2008 | 02:43 PM
modaddict's Avatar
modaddict
ORIGINAL: lukas77
You are 'determined' to have problems then...
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
