Lower control arm/torque box issue?
Old Jun 25, 2008 | 04:08 PM
fullboogie's Avatar
fullboogie
Default Lower control arm/torque box issue?
Pardon the ignorance, but my last Mustang was a 93 5.0 LX. Back in the day, Southside Machine Bars and other LCA's with solid/poly/spherical rod ends were all the rage because they gave great hookup on the street/track. Fast forward a few years, and everyone discovered that these bars can literally tear the torque boxes out of the car. I had to pay a ton of money to get mine repaired.
So my question is this - do the new cars suffer from the same problem when using aftermarket LCA's? If so, what preventative measures should be taken? Mine's a 5 speed and I plan on visiting the track with slicks (as I do with every car) very often, so new LCA's seem mandatory. Just want to be sure I do something about it now, before the damage occurs.
Thanks for your input.
Old Jun 25, 2008 | 05:49 PM
DarkFireGT's Avatar
DarkFireGT
Default RE: Lower control arm/torque box issue?
Haven't really heard of many problems. Most people go with the poly bushings. But if you're racing very often, then you may want to go with the spherical bearings.
Old Jun 25, 2008 | 06:04 PM
fullboogie's Avatar
fullboogie
I appreciate the input, but my inquiry was aimed at torque box reinforcement.
Old Jun 25, 2008 | 06:11 PM
moosestang's Avatar
moosestang
When you say torque boxes, you're talking about on the axle? If so, you can get them completely welded, they are only spot welded I believe. I don't think you'll have any problems unless you have a power adder. If you do, you can pick up a complete rear axle for $700 from new takeoff.com.
Old Jun 25, 2008 | 06:27 PM
fullboogie's Avatar
fullboogie
I'm talking about the point on the body where the LCA's attach. When you go to poly/solid/spherical rod ends, it puts a lot more stress on the mounting points - which are typically thin sheet metal brackets tack welded to the body. Even more of a problem when you relocate the rear mounting point downward.
Has anybody had any experience with this issue?
Old Jun 25, 2008 | 07:34 PM
DarkFireGT's Avatar
DarkFireGT
Again, I haven't heard of any problems. Only problems I've read about is where people that installed relocation brackets (for the rear mount of the LCA) didn't have them welded and caused them to bend. Haven't heard of one person having an issue with the front mount.
Dragonus18
Sep 9, 2015 01:21 AM
zanemoseley
Sep 6, 2015 12:58 PM
Emblazoned
Sep 3, 2015 10:45 PM
cbird1177711
Sep 2, 2015 04:12 PM
