GOOD OR BAD IDEA
Old Jun 29, 2008 | 02:34 AM
1morepart's Avatar
1morepart
Default GOOD OR BAD IDEA
i bought chevron's techron fuel system cleaner and i was wandering if it is safe....the bottle says it treats 12 gallons and to put it in an almost empty tank..........it also says 2x concentrated....is this good or bad for my gt
please reply
thanks everyone
jason
Old Jun 29, 2008 | 03:38 AM
sailing220's Avatar
sailing220
Default RE: GOOD OR BAD IDEA
Most octane boosters and fuel system cleaners are bad for your engine (will foul your plugs) but Chevron's Techron is the only one I've heard is ok to use....might want to wait for more replies because I'm not completely sure.
Old Jun 29, 2008 | 07:20 AM
cavediver's Avatar
cavediver
It's good stuff, the only kind I use. It's the same thing that is added to the Chevron gasoline you buy at the pump.
Old Jun 29, 2008 | 10:06 AM
vaporstang's Avatar
vaporstang
Just curious - why are you using this? I assume you're going to use it on your 2008? Is this for maintenanceor are you having a problem? If thisis for maintenance, how often should it be used? Thanks...
Old Jun 29, 2008 | 11:11 AM
wmtheflash's Avatar
wmtheflash
Yes, ask anyone with a C5 Corvette. Techron works. I know from personal experience.
The older Chevys can develop deposits on the fuel sender caused from high sulfur fuel, it makes the gas gauge go nuts.
Techron is recommended (aka GM fuel system cleaner) by GM and helped regulate the problem for me (doesn't work for everyone, some have senders that have simply failed). Techron really works, in my opinion, the question is, "Do you need it?".
I think I'll probably introduce Techron into the Mustang's fuel system, I just haven't decided the interval just yet. Maybe every 30k miles or every year or two. (The C5 will get it every oil change, but only because of the twitchy fuel sender and $900 bill for a new sender.)
Here's a tip. When you use Techron concentrate, mix it with Chevron gas. It already has Techron in it, so you're getting more bang for you buck.
In addition, you can start using top tier fuel to keep your fuel system clean all the time. The detergent levels in gasoline are not the same for all brands. There is no point in using a quality fuel system cleaner and then consuming gas with inferior detergents.
www.toptiergas.com
http://www.dallasnews.com/sharedcont...1.421b4a4.html
Old Jun 29, 2008 | 12:32 PM
birdoffire7's Avatar
birdoffire7
Put it in my Firebird yesterday. Been using it for years. It will be going in my 07 Mustang - still feel it's too new to need it yet.
Old Jun 29, 2008 | 12:47 PM
Gene K's Avatar
Gene K
ORIGINAL: vaporstang
These cars pull engine oil through the PCV system under high vacuum conditions.
Pulll the driver side tube and check it and you will see it yourself.
This leads to carbon build-upin the chambers which resultsinless tolerance for ignition advance.
Run either Techron, Gumout-Regane, or Seafoam time to time to clean this out.
Running Top Tier Rated Gasoline (Chevron-Texaco, Shell,BP-Amoco, QT, etc) will help reduce this build up between treatments.
Old Jun 29, 2008 | 02:31 PM
vaporstang's Avatar
vaporstang
I have been using Shell gas - I'm a believer in staying away from the off-brand names. I saw my local WallyWorld has the Techron fuel system cleaner. (They also had a Shell version - I suppose I should stick with the Techron). We don't have a Chevron station near me. I'll use fuel system donw theroad - I have under 3k miles.
Thanks...
Old Jun 29, 2008 | 03:31 PM
wmtheflash's Avatar
wmtheflash
Thanks...
Alternatively, you could go to Texaco. Texaco and Chevron merged a few years back. As a result Texaco gas also has Techron.
Old Jun 30, 2008 | 12:16 AM
1morepart's Avatar
1morepart
thanks
