Do it yourself trunk release?
Old Jul 8, 2008 | 07:49 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Default Do it yourself trunk release?
I saw this on another forum and wondered if anyone has tried it.
A do it yourself trunk release for our S197s/
I found it on allfordmustangs.com.
Thoughts?
Here's the link.
http://www.cherod.com/mustang/HowTo/TrunkRelease.htm
Old Jul 8, 2008 | 07:52 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Default RE: Do it yourself trunk release?
I just don't understand how this wire is telling the trunk to release when there is no such wire to the trunk in the first place?
Maybe I'm stupid but could someone chime in on this?
Old Jul 8, 2008 | 08:02 PM
grampa_stang's Avatar
grampa_stang
I've done it. A couple of notes though.
1. The switch in the write-up is too big/tall/high..as he mentions. When you close the glovebox a little hard
the trunk release button gets pushed.
solution: Radio Shack has at least 4 to choose from. I boughta round button (same color scheme)
it's low profile.Of course make sure it's a momentary switch.
2. Pay close attention to step 1 when you drill the hole. There's a metal bar behind the plastic.
Another thing...It might not be a bad idea tocover the entire area with tape as to minimize
scratching the plastic duringthe entire process and especially during drilling.
3. When pulling the white wire with pink stripe....well, I found that wire in 2 locations behind the kick panel.
So, if the 1st one doesn't work...look in the other harness.
Old Jul 8, 2008 | 08:04 PM
grampa_stang
ORIGINAL: iluvmycar
Yes there is actually...I tested that wire too. Just unwrap the wires on the decklid and you'll see the white/pink stripe.
to test it...just scrape some insulation off and touch it to ground...you'll hear a click.
Old Jul 8, 2008 | 08:08 PM
odiaz's Avatar
odiaz
Yeah, no problem. The car has an electric trunk release. When you press the button on your remote it sends a signal to the computer that sends an electrical impulse down a wire and causes the trunk release latch to activate. This signal basically cuases a short to ground on the wire that goes to this electrical latch.
The button works in the same way. The switch has two wires. One goes to ground and the other goes to the wire on the trunk release. When you press the button, it grounds the wire that goes to the trunk and this causes the latch to release.
When doing this mod, be careful not to cut any wires. You simply want to strip the insulation back on the wire to expose the copper wires. For best results, I would get a trunk release button from an SN95 mustang. You can get one on ebay or a junk yard for about $5.
Just follow the instructions and you'll be OK. If you have any questions just ask.
OD
Old Dec 26, 2009 | 09:16 AM
hockeyman8282's Avatar
hockeyman8282
ill need this for later this week when i install mine
Old Dec 26, 2009 | 10:07 AM
Nuke's Avatar
Nuke
This is coverd in another post this morning with the DIY link. It's the SJB that controls the release. That's why the associated wire doesn't go to the trunk.
Old Dec 26, 2009 | 10:28 AM
degeze's Avatar
degeze
I did it, and it works great. Very convenient.
Old Dec 26, 2009 | 10:46 AM
Johnboy7701's Avatar
Johnboy7701
Yup mine did mine too except in the glove box.
Old Dec 26, 2009 | 02:54 PM
hockeyman8282
how did u do it there when the wire for the trunk is on the other side of the car???
