Lowering: Guide?
Old Jul 10, 2008 | 02:10 AM
sharkbait20's Avatar
sharkbait20
Default Lowering: Guide?
if i rmember correctly, there was a post about lowering before with everything needed to know to do the job right.... butttttttt, the search isnt working so unless somebodys got the link on hand, lets make a new one, because i am interested as well.
To start, the following is what I know to be required to properly lower an S197; others please chime in where i missed stuff.
Lowering Springs - To shorten the distance between the tops and bottoms of the struts/shocks (obvi)
Shocks/Struts - Adds cushion to the new springs (which are stiffer than the stock springs) making for a less harsh and more enjoyable ride (comfort and performance). From what I understand, it is generally not advised to simply replace the stock springs with lowering springs without swapping out the shocks/struts as well due to harsh ride quality
Camber Kit/Bolts - corrects camber from lowering the height of the axles. Without adjusting the camber, the wheels/tires would have too much (negative/positive?) camber causing
excess tire wear and a harsh ride.
Lower Control Arms - Adjusts pinion angle (someone help me out here....)
In extreme lowering cases, a Driveshaft Loop may be required to prevent the driveshaft from bottoming out.
Not sure where things differ when it comes to coil-overs, so if someone wants to chime in here that would be great.
any other information or corrections are welcome and applauded.
Thanks
Sharkbait20
Old Jul 10, 2008 | 06:58 AM
Argonaut's Avatar
Argonaut
Default RE: Lowering: Guide?
Here's the link to the Lowering Guide. If you go to 2005 -2008 Mustangs >> 4.6L V8 Specific >> Handling Performance section it is a sticky at the top of the page. This subject has been discussed ad nauseam: https://mustangforums.com/m_934501/tm.htm
Sep 25, 2015 06:30 PM
algregory
Sep 6, 2015 05:52 PM
SilverStallion05
Sep 5, 2015 10:48 AM
