TIRE PRESSURE SENSOR
Old Jul 16, 2008 | 02:39 AM
LOW E.T.'s Avatar
LOW E.T.
Default TIRE PRESSURE SENSOR
WITH THE PURCHASE OF AFTER MARKET RIMS HOW WILL IT AFFECT THIS SYSTEM. AND CAN IT BE SHUT OFF OR TUNED OUT ?
Old Jul 16, 2008 | 02:43 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: TIRE PRESSURE SENSOR
You will have to either get new bands and put them in the new rims or make a pressure tube to put the sensors in and leave in the trunk
Old Jul 16, 2008 | 05:40 AM
wingman75's Avatar
wingman75
Or just press reset. No big deal!
Old Jul 16, 2008 | 07:14 AM
ckone0814's Avatar
ckone0814
I'm using the "just press reset" method and I agree it's not a hassle. It's not my DD though... I may feel differently if it was.
Old Jul 16, 2008 | 07:27 AM
billyjo's Avatar
billyjo
well like he said first you can put them all in your spare where the pressure is the same. i would try that if the reset button doesn't work
Old Jul 16, 2008 | 10:39 AM
Nuke's Avatar
Nuke
Those are the options above. I bought strap kits from AmericanMuscle andhad the shop swap the sensors to the new wheels. They didn't charge me extra to pull the sensors from the old wheels and install the straps and sensors on the new ones.
Old Jul 16, 2008 | 10:53 AM
157dB's Avatar
157dB
Cut & Paste Expert
TPMS is a Govt mandated system.
Cant be disabled or shut off.
It can be tricked.
You have to either transfer the sensors to the new wheels
or put them in a piece of pressurized PVC tube in the trunk.
Old Jul 16, 2008 | 10:58 AM
2L8IWIN's Avatar
2L8IWIN
I just hit Reset (and turn TCS off) each time I start the car, but I only drive it once a week or so.
white07's Avatar
white07
I press reset. After A while its such a habit its kind of like turning the key.
Old Jul 16, 2008 | 01:48 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
What happens if you get into an accident and kill someone because of a tire that was not properly inflated (or something along those lines)??. I'm sure you can have a hefty lawsuit or government action against you.
Play it safe and do it the right way - my opinion of course
