Driveshaft Loops, when do you need them at the track.
What are the rules for NHRA for drives shaft loops? Do I need a front and back loops or will a front only work? what the cheaps one that doesn't require me to drill or remove the ds?
Thanks
Ryan
Thanks
Ryan
RE: Driveshaft Loops, when do you need them at the track.
I'm pretty sure NHRA requires a front loop if you're running slicks. I'm not sure what the ET cutoff is for non-slicks running cars. I have a BMR front loop but you have to remove the front of the DS to get it on. I'm not sure there is a loop that doesn't require you to remove the DS to install it.
If you're running faster than 11.5 or slicks, you'll need one. If you're running any sticky tire or a one piece, it's a good idea to have at least a front one. A rear one is just extra protection.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
