Rotating Tires
Old Jul 17, 2008 | 10:47 AM
05RedHead's Avatar
05RedHead
Default Rotating Tires
Can we rotate tires on the S197 GT with stock rims/tires?
Old Jul 17, 2008 | 10:54 AM
BLACKSTEED611's Avatar
BLACKSTEED611
Default RE: Rotating Tires
yup same sizes
Old Jul 17, 2008 | 11:16 AM
05RedHead's Avatar
05RedHead
Thanks for the reply. I should specify - I have been rotating my tires every 5k, but i was showing a friend here at work the Edmunds.com maint. schedule for every car. I pulled up mine, and there's nothing about rotating tires on there...
Old Jul 17, 2008 | 11:31 AM
Goldenpony's Avatar
Goldenpony
I rotate mine back to front, front to back. No changing sides.
Old Jul 17, 2008 | 12:18 PM
Nuke's Avatar
Nuke
As long as your tires are bi-directional and you haven't mixed sizes front to rear, yes you can rotate. If your tires are directional you can only rotate front to rear on theeach side PROVIDING (again) you don't have mixed sizes.
Old Jul 17, 2008 | 03:38 PM
157dB's Avatar
157dB
Cut & Paste Expert
fronts straight back, cross the rears to the front
Old Jul 17, 2008 | 05:38 PM
Goldenpony's Avatar
Goldenpony
These guys may be right about crossing the rears to the front. I just remember when radials first came out we were warned not to change direction of rotation. I have always just gone fronts to rear, rears to front.
Old Jul 17, 2008 | 11:13 PM
timothyrw's Avatar
timothyrw
+1 it's in the manual, except it is rears to the front, cross the fronts to the rear. just did mine.
ORIGINAL: 157db
Old Jul 18, 2008 | 11:23 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Goldenpony
Those days of same side radials to avoid tread seperation are long gone.
Tire Technology has come a long way since then.
Old Jul 18, 2008 | 11:31 AM
jmanpatsfan's Avatar
jmanpatsfan
How are the TPMS sensors reprogrammed?
