TPS help
Old Jul 18, 2008 | 08:47 PM
ohfiveride's Avatar
ohfiveride
Default TPS help
i think my tps is bad..how do i know....where is it located , can i change/test it myself, and how much $ am i looking to spend ?
Old Jul 18, 2008 | 08:55 PM
grabberorange1's Avatar
grabberorange1
Default RE: TPS help
what makes you think its bad? What year stang?
Old Jul 18, 2008 | 08:56 PM
bb816331's Avatar
bb816331
I ♥ Acer
Throttle position sensor? Well here's what happened to me. When I bought my 06 GT a week ago, the dumb facks sprayed the entire engine bay as a part of "detailing" it[:@]. This got water on either the connects or actual TPS sensor, which would cause it to short out. I would be driving along, then the car would lose all it's power, stall, and check engine lights would come on. If it didn't stall, the car would lose like 80% of its power. Drove like complete ****. But mine would only do it once, then I would restart the car, and it would be fine. Now that the damn thing has had time to dry out, it doesn't do it anymore. I think the TPS is located alongside the TB. Should be easy to swap out, don't know how much thought...What's yours doing?
Old Jul 18, 2008 | 09:06 PM
ohfiveride's Avatar
ohfiveride
i have an 05 gt which had been having the fluctuating idle problem (will go very low then high and back and forth until it stalls) and i thought i fixed the problem by replacing the fuel filter, air filter, and cleaning the throttle body.....started her up and ran really well, then today i go to start the engine and it starts to stumble again and failsafe mode came up but no codes as usual....this has been going on for 3 weeks now....ive been reading online about alot of guys having bad throttle positions sensors so im hoping that is it...otherwise im gonna have to fork up more cash for a mechanic as i am out of warranty with 44,000
Old Jul 19, 2008 | 09:16 AM
ohfiveride's Avatar
ohfiveride
bumpies
Old Jul 19, 2008 | 09:34 AM
157dB's Avatar
157dB
Cut & Paste Expert
Readies
http://iihs.net/fsm/?dir=195&viewfil...tle%20Body.pdf
http://iihs.net/fsm/?dir=5
http://iihs.net/fsm/?dir=9&viewfile=Step%203-%20No%20Diagnostic%20Trouble%20Codes%20(DTCs)%20Pr esent%20Symptom%20Charts.pdf
Are you throwing any DTCs?
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
