Uneven Exhaust Tips!
Old Jul 18, 2008 | 11:07 PM
AlloySixxer's Avatar
AlloySixxer
Default Uneven Exhaust Tips!
Ok I got my JBA H/Mids and Borla Stingers installed for $60(local shop left the mufflers hanging crappy), then had the hangars bent later for $50 to have the mufflers hanging right(Meineke). Now I don't know how long it's been like this, but I just noticed my left tip sticks out farther then my right one [:@]. Maybe 1/2"-3/4". Looking stright down at the muffler on the left you can read the Borla Logo, but on the right you can barely see it. It's bugging me a little so what can I do? I don't want to start moving stuff that I don't know how to fix and then ruin the alignment because the mufflers are finally hanging at the right height. If you must have pics, I'll post them tomorrow, it's too dark now.
Thanks!
Old Jul 18, 2008 | 11:12 PM
S197_GTvert's Avatar
S197_GTvert
Default RE: Uneven Exhaust Tips!
my car came like that from the stealership[>:]
Old Jul 19, 2008 | 12:16 AM
kinglasher's Avatar
kinglasher
Try loosening the over axle pipe up by the H part and pull the pipe out a bit till they look right and tighten back up ( 4 bolts i believe ). It's really hard to get them 100% Perfect but u can getit pretty close. Ask someone to spot you while your under pullingit out till its evensou dont have to keepgoin back n forth from under the car to the back to check it out.
Make sure u use stands just to be safe while your under there.
Hope it helps.
Old Jul 19, 2008 | 03:48 PM
AlloySixxer
Thanks for the help but I don't have stands [:@]. It's a tight fit without them, so I don't know what I'm gonna do. Any other suggestions?
Old Jul 19, 2008 | 04:27 PM
StickShifty's Avatar
StickShifty
you paid someone to bend the hangers. most of the tip you just back the bolt off - adjust - and tighten. wala.
Old Jul 19, 2008 | 04:53 PM
AlloySixxer
ORIGINAL: StickShifty
Unfortunately...[&:]Anyway your saying to undo the bolt where the muffler meets the midpipe and adjust from there?
Old Jul 19, 2008 | 05:35 PM
2cokeman's Avatar
2cokeman
Uneven exhaust tips come standard on most Mustangs and Shelby's are a little better but far from perfect as well!![:@]
Old Jul 19, 2008 | 08:06 PM
AlloySixxer
ORIGINAL: 2cokeman
Yes, but my exhaust is aftermarket. I'm just wondering if I try moving it, should I move the muffler where it connects to the midpipe or move the midpipe where it connects to the H?
Old Jul 19, 2008 | 08:41 PM
A_Drunken_Llama's Avatar
A_Drunken_Llama
meineke can fix that for you too [8D]
Old Jul 19, 2008 | 09:06 PM
AlloySixxer
Meineke lol...yeah right...
