I need your help, weird sound
Old Jul 22, 2008 | 10:07 AM
gnrpatience's Avatar
gnrpatience
Default I need your help, weird sound
Hello,
Its been 2 months since i took my car for 20,000kms. Yesterday i notice a weird sound on one of the wheels, when i get home i start reviewing each tire and found that the right front tire its missing the lock nut. I dont know the reason its missing, the only thing im thinking is that the agency left it loose so it fell.
Now im listening a sound mostly when i turn to the left is like a "click" but its not constant its just a cycle click.
Does anyone know if missing the nut lock can cause this sound or what else can i check in the tire to see why is that sound ?
Thanks
Old Jul 22, 2008 | 10:19 AM
buster's Avatar
buster
Default RE: I need your help, weird sound
First of all, make sure all the remaining nuts are tight (on all the wheels). I now check all mechanics work after my former mechanic left the front wheels loose. ( I was really happy about that one. ) Wiggle the tire and if it moves at all, you could have a bad bearing. Either way noises from the wheel could be deadly, so take it to a qualified mechanic and have it checked.
Old Jul 22, 2008 | 10:29 AM
gnrpatience
Yeap Buster,
I checked all the remaining nuts on all wheels and found another one loose. So i tightened perfectly. Im still missing the lock nut and as i know each nut has its specific lock so i will need to buy another lock with it each nuts.
I did wiggle the tire but its ok the tire has the remaining 4 nuts tightened.
THanks
Old Jul 22, 2008 | 12:13 PM
gnrpatience
I just went down to the lot park and noticed that this sounds is just when the car is hot, i just started it and drive it a little, make some turns but cant listen anything. After the car warm up the sound start again.
Any ideas?
Thanks
Old Aug 27, 2008 | 09:04 AM
buster's Avatar
buster
bad wheel bearing?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
mungodrums
Sep 28, 2015 10:54 PM
