Throttle body plug removal question
Old Jul 22, 2008 | 12:00 PM
SlinkyBMX's Avatar
SlinkyBMX
Default Throttle body plug removal question
I am removing my throttle body for paint. Looking at your engine from the front at the throttle body there is a plug that I cannot get off. It has a red tab that I assume you pull back, then you should pull and unplug. Well I been wiggling and pulling to no avail. Am I doing the right thing, or is there a secret to it? It is attached to a plate that is on the throttle body connected by about 6-8 torx screws.
Old Jul 22, 2008 | 12:27 PM
billyjo's Avatar
billyjo
Default RE: Throttle body plug removal question
they some times get together and want to stay. you need to pull out the tab and then pull it off. you are doing it right just keep trying but try not to break. a small screw driver may help but dont force it just use it to assist
Old Jul 22, 2008 | 01:52 PM
sailing220's Avatar
sailing220
NO do not pry it with a screw driver.
Pull the little red tab back, then press down on the top part, there is a little tab to press down.
Old Jul 22, 2008 | 02:14 PM
surf808's Avatar
surf808
Yeah you have to pull that red tab out. It covers another tab that you have to depress and then pull it out.
Old Jul 22, 2008 | 02:16 PM
rmssch89's Avatar
rmssch89
ORIGINAL: surf808
I learned this the hard way. And of course Ford wanted about 30 bucks for the new connector.
Old Jul 22, 2008 | 03:45 PM
SlinkyBMX's Avatar
SlinkyBMX
Thanks guys! Its great when stuff just works! Pulled back the red tab then pressed in the center piece and VOLA!
djbigskrilla
Sep 20, 2022 01:04 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
my96mustang
Aug 24, 2015 06:12 AM
stanngg
Aug 12, 2015 03:43 PM
