UPDATE: Grrr Battery bug finally bit me - why no warning?
#22
UPDATE Grrrr. RE: Battery bug finally bit me - why no warning?
Update: 1. It's not a battery/terminal connection issue...they'were spotless and tight.
2. New battery died after approx 20 minsof driving.
3. Luckily still under warranty..free tow to the dealer 3 miles away.
Hopefully they'll have it fixed by tomorrow.I'm thinking alternator. Told them not to flash
a damn thing.
a damn thing.
#23
ORIGINAL: Nuke
Lead-acid batteries chronically fail due to structural collapse without warning. The internal support structures tend to degrade over time with no impact on battery voltage or capacity until it fails catastrophically. Some batteries are constructed better than others. A car that has a tighter suspension MAY be harder on a battery in this respect than a luxury sedan.
If I was experiencing multiple failures of this type, I might consider a marine starting battery. They're constructed withmore robustinternalsupportsincludingsuperior plate design and spacers.
Second, I have never heard the word "spacers" regarding battery construction. I would assume you mean the separator that keeps the plates from touching. Most automotive batteries use an envelope type separator, which envelopes the whole plate, sides and all. It's like slipping a lead plate in an envelope. Most marine batteries use a leaf separator, which is a flat piece of material that does not protect the sides of the plates if the plates would slip from vibration in the cell.
Marine batteries are not as vibration-resistant as automotive batteries. If a battery fails overnight, it generally is a failure of the intercell weld. Failure over time (slow discharge) is generally a sign of plate degredation, or separator compromise. If I thought my battery was failing because of vibration due to a stiff suspension, I would purchase a light truck battery, or one made for four wheel drive vehicles. These batteries usually have a top or bottom bond of epoxy to keep the plates from shifting.
And if it were me, I would buy an Interstate. Consistently at the top of the battery ratings. Costs a little more though. But that's just one guy's opinion.
#24
RE: UPDATE Grrrr. RE: Battery bug finally bit me - why no warning?
ORIGINAL: grampa_stang
a damn thing.
a damn thing.
