new gt500 splitter installed with pics
#21
RE: new gt500 splitter installed with pics
what are you talking about, it doesnt droop at all, nowhere it sits perfectly flush with my bumper...and yea its a ford part, call your dealer and tell me its only $75
#23
Thats an easy one.....do a ten minute burnout then badabing badaboom NEW TIRES!![sm=wootwoot.gif]
ORIGINAL: tn_gt
now im just waitin on these brand new tires to wear down so i can put some thicker ones on the front, that will help out a whole lot too
#24
lights were 300 with the headlights foglights and black bumper signals, and lol i wish that would work but my back ones are the right size, my front ones are the ones that are too skinny and i dont wanna waste them, there were expensive
#26
tn_gt,
If you don't mind me asking. Would you post a link to the specific instructions you used to modify and isntall it?
There have been several versions and since you said you are having no drooping, I'd like to try the one you went with.
Mine is going on tommorrow.
Thanks!
Thanks!
#27
well basically all i did was like the link posted earlier, i just shaved down the outer side pieces like the pics earlier and used the 4 screws on the bottom of the bumper and they fit perfectly, then i only used one screw on the fender well and it was the upper screw and thats all i needed, its stiff as a board and no flex or anything
#28
Which post? One had them cutting the whole area while the other had it taking the top part of the area that rasies.
Can you post a link of the one u used?
PWEEASE?
PWEEASE?
#29
Don't cut the entire sides... Just the crossbeam section like you have seen before.
Then in the fenderwells, don't use the stock bolt. Pull the fenderwell pieces in a couple inches and bolt in with the hardware that you bought.
#30
Ok so don't cut the entire section out like on this thread...
http://forums.stangnet.com/738399-gt...lation-gt.html
But only the crossbeam that is actully lifted on that area?
Do you have any drooping Boozhey?
I wonder if cutting the entire area is what is causing the drooping people speak of?
