Ones with the Steeda CAI, chime in please
After installing the cai, I noticed the heat shield is hitting the hood, has anyone come across this?? I took the heat shield off and cut 3/8" off the back, at the highest point. Reinstalled it and it still hits...what the??? Am I missing something here?? Both grommets are in, everything on the bottom is flush with the car. I wouldnt make an issue out of it, but after I washed the car, I opened the hood and there was a puddle of water laying on the bottom of the heat shield, so there isnt a good seal from the hood. I am going to call Steeda in the morning and ask them about it. Anyone have any input on this???
RE: Ones with the Steeda CAI, chime in please
ORIGINAL: howarmat
heat shields are suppose to hit the hood when closed??
My heat shield does hit the insulating blanket on the hood but not enough to prevent closing the hood. And don't expect to not get any water in the engine compartment when you hit the hood gaps with a hose. The engine bay is NOT sealed along both edges. I pop the hood while finishing up drying to wipe things down in the engine bay and often have some water laying in the heat shield and some drops on the end of the air filter trim. It's no big deal, IMO.
I get a little water on the bottom of the heat sheild too after washing my car, but it doesn't have anything to do with the heat sheild hitting the hood. The water comes from thegap between the hood and fender. I normally dry off under my hood anyway after a wash.
If you have a cervini's hood it's a mess... I had to cut down the heat sheild remove the rubber stoppers. Then when I installed the carbon fiber inlet tube by steeda I had to hack the crap out of the bottom corner of the heat shield so rubber boots on the inlet tube to the MAF wouldn't kink... The cervini's hood has a channel that smashed the cone down.. Big PITA. No puddles nothing though....
i have the steeda CAI but i have never had issues with getting puddles of water under my hood. the heat shield should hit your hood liner to reject as much hot air as possible but you should not have issues with closing the hood. if the hood shuts well, then you should be fine
