Engine is hesitating and threw a code
Old Jul 28, 2008 | 09:12 PM
millertyme4lyfe's Avatar
millertyme4lyfe
Default Engine is hesitating and threw a code
Need some advise on the problem. My car started hesitating at partial throttle and will also fall flat on its face when at WOT high in the RPM range. This started a few days ago and the car finally threw a code "P0193 Fuel Rail Pressure Sensor Circuit High Input." What could cause this? Dirty fuel system or something worse. I had a 93 oct tune in the car and when the hesitation first started i went back to stock and the condition was still there. My only mods are and off road H and UDP's. Thanks in advance.
Old Jul 28, 2008 | 10:00 PM
nite's Avatar
nite
Default RE: Engine is hesitating and threw a code
I would start right at theFR pressure sensor, as it's most likely shot. Shouldn't take but a couple minutes to swap it out.
Old Jul 29, 2008 | 02:52 PM
millertyme4lyfe
BUMP
Thanks for the responce nite. Anymore input anyone else could give. I Just want to make sure the sensor has replaced or if it could be cleaned.
Thanks
Mike
Old Jul 29, 2008 | 04:39 PM
157dB's Avatar
157dB
Cut & Paste Expert
There are outlined Ford service flow charts.
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
PinPointTests
Old Jul 30, 2008 | 01:20 PM
millertyme4lyfe
Thanks for that link it really helped.. discovered the wire connector is bad not the sensor.... Ford has the connector for $36 and my dealer would replace it for 1 hour of labor... sound fair?
Old Jul 30, 2008 | 01:48 PM
abrush's Avatar
abrush
I don't know about the hour to repair it. That seems quite lenghty to me just to replace a connector but I suposse it depends on how hard it is to get to it. I think I would just buy the new connector and do it myself.
Old Jul 30, 2008 | 03:06 PM
SCCAGT's Avatar
SCCAGT
One hour is pretty much the minimum a dealer charges for labor on anything. So thats to be expected. But it is easy enough you should be able to accomplish it by yourself and save the $100 install + tax.
Old Jul 30, 2008 | 03:12 PM
mustangman02232's Avatar
mustangman02232
how many miles on your car and when was the fuel filter last done?
jpplaw
Mar 19, 2025 08:53 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
microgt
Aug 20, 2015 07:12 AM
