solved the leaks into the passanger seat
after alot of trouble and research i am pleased to report that it is a simple fix that can be done without any tools.
If your Mustang is leaking water into the passenger floor after a rain storm like mine did just pop your hood, reach just to the right of the battery on the fire wall behind a wire bundle and pull the rubber grommet (plug/stopper looking thing)that has become clogged!!! Be ready to get your arm wet because there's probably a gallon of water still sitting in there... the water was getting into the cabin when it was at a level that allowed it to flood your cabin air filter!
When you pull the clogged grommet the leak will disappear!
Your welcome!!!
Your welcome!!!
RE: solved the leaks into the passanger seat
Figured it out after reading all kinds of people with the same issue and absolutely no help from the dealers/ford customer care people got fed up and took the dashboard apart to find the water entry point, after i had the point of entry it was simple to find the "puddle" that was feeding the leak. Now that ive done all the disassembly and reassembly i know that i could have just popped out the "tube" that’s supposed to act as a drain line that gets all clogged... I actually recommend that all 05-06 owners check the little rubber grommet/tube/plug whatever it is for blockage BEFOR they get the issue and a wet floor board. Might be a good idea to add it to the "check this" list at oil change time.
PS - attached is a picture of the removed rubber gromet tube drain thing that got full of crap and made the water pool up and flood my pasanger floor board
ORIGINAL: Goldie543
I cut the bottom off mine some time back, the grommets arenow open and the crap flows through much easier.
Someday maybe the search will be working again, there was a huge discussion on the leaking problems awhile back.
