While I'm doing the 2.8L KB!!!
Old Aug 3, 2008 | 08:46 AM
PLstang's Avatar
PLstang
Default While I'm doing the 2.8L KB!!!
So my mammoth 2.8LKB showed up the other day!
However, my project kind of changed a little......
I have decided to Port and Polish the heads and install stage 3 comp cams. While I'm at it I'm going to be putting in a 5.4L Monster Mod shortblock from MMR!
MMR 5.4 Monster MOD 1500-2000HP!! 2V, 3V or 4V
*Cast Iron Block FULL RACE PREP, de-burred and custom Hone for Chrome faced ringset.
*New 4340 4.165 stroke Forged Crankshaft, FULL RACE PREP- includes additional heat treat w/micro polished journals, shot peened and magnafluxed at no extra charge
*New 4340 6.658 Manley Pro-series Billet Rods ( These US made rods are shotpeened, magnafluxed and weight matched to bring you the finest I-beam rod available for your 5.4), MMR gives the rod a final deep tempering to increase strength up to 300%
*New Forged Manley or Diamond 2618 Custom pistons 3.552-3.572 Bore size .08 Deck (High or low compression)
*Total Seal file fit rings with Chrome faced combustion/top ring for ultimate high cylinder pressure sealing(precision file fit to your application, nitrous, blower, turbo or N/A)
*Federal Mogul Competition series heat treated Rod and Main bearings, each bearing is hand deburred at the parting line for perfect fit and oil clearance.
*ARP main stud kit for maintaining correct cap location under the hardest of loads
*Complete Pro Assembly and Balancing for the smoothest, highest revving shortblock available, Pre-Lubricated with Royal Purple Assembly Lube and spin tested. Lastly 3 technicians sign off on your new engine prior to packaging and crating.
Shortblock Options:
Coated Pistons (ceramic dome/teflon skirt)
MMR Street/Racing Oil Pump (highly recommended)
MMR/Felpro Extreme Duty Headgaskets
ARP Headstuds
ARP Mainstuds (recommended for 600+HP)
MMR windage tray and hardware kit (+15HP)
Old Aug 3, 2008 | 09:16 AM
Stkjock's Avatar
Stkjock
Retired Mod
Default RE: While I'm doing the 2.8L KB!!!
so your putting the 2.8 on a 5.4 4V instead?
looking for 700+ @ the tire are we?
Old Aug 3, 2008 | 10:13 AM
native05gt's Avatar
native05gt
im lost....didnt you already swap to the motor? wont that be another swap with the shortblock?? forgive me if its funny to you, i understood everything until the shortblock
Old Aug 3, 2008 | 11:23 AM
PLstang's Avatar
PLstang
Let me clarify.
Yes I have a GT500 motor in my car currently making 670rwhp. I am going to port the heads and install cams on my existing 4V heads. I am installing a built short block so I can turn up the power. The GT500's weak point is still the rods, the pistons are ok, for the most part. The new shortblock will come with better components then the GT500 shortblock I have. I will then get my existing block reworked with new components for another project I am looking at or as a back up.
I am really wanting to hit 900+ rwhp with the blower and spray through the automatic trans. I just didn't want to chance that with the stock block. I figured I'd rather have a spare shortblock then a piece of junk when I kicked a rod![:@]
Old Aug 3, 2008 | 11:32 AM
brendend's Avatar
brendend
care to donate any spare motors? lol
Old Aug 3, 2008 | 12:28 PM
bmk's Avatar
bmk
damn man.. you car is sweet.. what do you think your track times will be?
Old Aug 3, 2008 | 01:58 PM
PLstang's Avatar
PLstang
Well if I don't need a 9 second license after this......I think I'll loose it! LOL
CPR76Mustang
Mustang II Section
Aug 31, 2010 07:29 AM
StangJunkie04
May 17, 2008 03:15 AM
94black5.0
Oct 21, 2006 08:30 PM
Justabear
Aug 4, 2006 07:19 PM
1979ghia
Feb 24, 2006 12:56 PM
