Spring change
Old Aug 5, 2008 | 08:38 AM
IN2FORD's Avatar
IN2FORD
Default Spring change
I friend of mine has a new Bullitt and he is wanting to install some drop springs. From what he is reading, it is telling him he needs to change swaybars, struts and springs at once. Is that really necessary, or can you install drop springs from Eibach or someplace and still be o.k.?
I am use to the foxbody stuff, so really don't know how the front ends are setup.
Barry
Old Aug 5, 2008 | 08:41 AM
blackice05's Avatar
blackice05
Default RE: Spring change
you can do just the spings, a rear panhard bar might be needed to correct the offset of the rear. It will shift with the new springs. The stock shocks will wear faster with the drop springs, you can use the stockers if you want but its not "needed"
2007StangV6
Jan 28, 2016 06:09 PM
PullTab
Oct 30, 2015 08:46 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
