Would like to see pics of rear stabilzers
Would some of you guys mind posting some pics of your rear stabilzers and other componenets? I would like to see the difference between the V6 stock, the V6 Pony Package, and the GT stock rear end.
RE: Would like to see pics of rear stabilzers
V6, no sway bar.
PP, 18mm rear sway bar
GT, 20mm rear sway bar
Here is a pic of my rear end.
Roush shocks and springs along with
a 20mm GT take-off sway bay and
Prothane poly bushings.
[IMG]local://upfiles/69445/4C15B3DE8A3B417A92C2784B547C1CFA.jpg[/IMG]
ORIGINAL: 157db
V6, no sway bar.
V6, no sway bar.
I have upgraded a lot of my parts from stock but this is a list of what I have now...
Tokico D-Spec Fully Adjustable Struts & Shocks
H&R Super Sport Springs
BMR Tubular Adjustable Panhard Bar
BMR Tubular Upper Panhard Bar Support
BMR Adjustable "Street" Lower Control Arms
BMR Control Arm Relocation Brackets
BMR Rear 7/8" Swaybar (w/ Mounting Bushing + Billet End Links)
This is the H&R 26mm bar (dark finish); the other is ADDCO's 7/8ths bar.
http://www.fototime.com/inv/613DF19F74CD1B1
Thanks for the info and photos, 157db. I have two questions. Is that just pretty much an easy bolt-on install? Also, what do you call the black bar right in front of your sway bar (it is stock on the V6)?
ORIGINAL: mpatilla
Wow, degeze! That looks awesome! How is the ride?
ORIGINAL: mpatilla
locates the rear axle from side to side and travels
in an arc with up and down rearsuspension travel.
Its a simple install for either the front or rear sway bar.
You need the Ford hardware if you dont have a PP rear
sway bar. Make sure the GT take-off sway is from a coupe
if you have a coupe and from a vert if you have a vert.
They (6 bolts, 6 nuts) areabout $40 from Ford.
Shock Absorber upper nut30 ft-Lbs
Shock Absorber lower bolt85 ft-Lbs
Panhard rod-to-body mount bolt129 ft-Lbs
Panhard rod-to-axle bolt129 ft-Lbs
Stabilizer bar link bolts85 ft-Lbs
Stabilizer bar bracket nuts52 ft-Lbs
[IMG]local://upfiles/69445/D853EE4407DB4848BBB9CD678E0299C3.jpg[/IMG]
09-08-2015 11:50 AM
