New Shoes!!! Finally!!!
ORIGINAL: danbevsv6rumbler
Well if you think about it, your front tires will wear a little differently than the rear due to camber/caster/toe... I know my camber is around -1.5 deg right now which really doesn't help the matter. But since all the wheels are the same size, I can rotate out the tires and make them last longer per set versus not being able to rotate the tires and running into problems sooner when the front tires I couldn't rotate develop dangerous uneven wear... do i make sense? lol.
Norm
Thanks! That's a negative on stock suspension
My car is lowered via Eibach Pro-kits... I should fix my sig again haha.
Thanks again everyone.
Well I was hoping that these wheels wouldn't have this problem, but I do have the infamous speed wobble... I'm gonna go ahead and take off all the retaining clips and hope that it cures my steering wheel shake above 45/50 mph.
Other than that though I still have no complaints!
ORIGINAL: xROBxCOREx
What retaining clips are you talking about? The weight balalncers on the wheel themselves? It could just be that they did a ****ty job balancing them.
