Taking headlights off
Old Aug 9, 2008 | 08:26 PM
SlinkyBMX's Avatar
SlinkyBMX
Default Taking headlights off
I need to remove my headlights to install some hood pins. I see the obvious screws on top with the plastic pin. How many more screws are there, and how do I get to them? Thanks!
Old Aug 9, 2008 | 08:31 PM
mlcrycc's Avatar
mlcrycc
Default RE: Taking headlights off
I believe you need to remove the front bumper cover to remove the headlights....
Why the headlight removal for hoodpins??
Old Aug 9, 2008 | 08:53 PM
SlinkyBMX's Avatar
SlinkyBMX
I just got the Cervini ram air IV hood. The pins have to mount way out to the sides. So I am going to mount them where the bump stops are. If you have the bump stop removed and look straight down thru the hole its solid. I need to drill thru that and put a nut on the other side. I dont even know yet if the nut will fit between the light and the beam.... Then I am going to drill out the rubber bump and slip it over the pin.
Anyone have any other input on this, jeeze I hope I don't have to remove the cover.....[:@]
Old Aug 9, 2008 | 09:21 PM
mlcrycc's Avatar
mlcrycc
http://www.2005stang.com/gallery/alb...1/headlamp.pdf
http://www.2005stang.com/gallery/alb...t%20bumper.pdf
Sorry........
Old Aug 10, 2008 | 09:44 AM
157dB's Avatar
157dB
Cut & Paste Expert
The Ford Way
But you must do this first [:'(]
StalkerGT
Nov 28, 2015 03:09 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mrappe
Sep 26, 2015 10:16 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
