gear install nightmare!
Old Aug 10, 2008 | 11:46 AM
  #21
Diabolical!'s Avatar
Diabolical!
Default RE: gear install nightmare!
ORIGINAL: duckbubbles
Are the gears from Motive? Been hearing a lot about gear noise/whine from these. Must be a production problem.
Frank
[align=left][/align]
Definitely not an issue with the parts. Gear installs have to be done with EXTREMELY precise tolerances. It was a poor install, plain and simple.
Old Aug 10, 2008 | 11:59 AM
  #22
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Not trying to hijack but uh... i have some slight whining when cruising on the highway... is it a big deal and i should get it looked at? The noise doesn't bother me...
Old Aug 10, 2008 | 12:11 PM
  #23
illin's Avatar
illin
Pick a shop close to your house...if only 10ish miles, you should be ok. Hopefully.
If not, you are going to get an expensive lesson in proper installation.
Old Aug 10, 2008 | 12:39 PM
  #24
thewarmachine's Avatar
thewarmachine
Hey, man, if it's any consolation, your GT/CS front bumper looks killer!
Old Aug 10, 2008 | 01:04 PM
  #25
tungsten07's Avatar
tungsten07
lol hey thanks. haha I'm thinking about now after having the car roll off the lift and getting the back scratched up putting on the gt/cs rear as well and painting the whole bumper body color like i did with the front. gotta make lemonade out of lemons i guess[8D]
Old Aug 10, 2008 | 01:09 PM
  #26
Rubrignitz's Avatar
Rubrignitz
I don't think you're in that bad of shape bro, but he scratched up your rear taking it off the jacks?? Gotta be a lawsuit in here somewhere...[8D]
Old Aug 10, 2008 | 03:57 PM
  #27
tungsten07's Avatar
tungsten07
actually he has a lift in his garage at home and lowering it off the lift he forgot to put the e-brake on and as soon as the wheels touched the ground the car rolled back right into the front of his car in the driveway. actuallyi've got togive ford credit on that one. i jumped in between the two cars and was prepared to take the hit but then i jumped out of the way and when it hit his jeep the bumper went in about 8 inches and then popped right out leaving nothing but a scratch! and a SMALL crease on each side of the license plate about 1 inch long. i thought it was going to be way worst to be honest.
Old Aug 11, 2008 | 08:48 AM
  #28
jbhunter's Avatar
jbhunter
Well.. now I am scared. Guess I'll call the shop that said that they would do mine and see how many s197's he has really done.
Old Aug 17, 2008 | 10:06 AM
  #29
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Rubrignitz
Ok, thanks for clearing that up. So everytime you re-adjust the pinion it requires a new crush-sleeve... I've ALWAYS had to purchase an install kit with gear replacement. Never attempted that myself (along with LT headers) but have done everything else. I wouldn't trust some "buddy" for gear upgrade. Performance shop for that.
You should be able to get it to someone who knows what they're doing and they can correct. The FRPP gears are heat-treated and pre-conditioned so they should be able to fix them. You don't have THAT many miles on them yet.
Yes, the Ford Workshop manual tells you what shims the pinoin needs
from the reading on the dial indicator so you might only have to waste
one crush sleeve with a base set amount of pinion shims to get
the dial indicator reading as to what shims it really needs from the
Ford Pinion Shim chart in the workshop manual. I would not dare
work on any major assemblies of the S197 witout the workshop manual.
Not a Hayneeeiys or a Chilllllytons, mind you.
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 3, 2015 07:14 PM
