Alternator Output
Old May 12, 2005 | 02:07 PM
Steven6095's Avatar
Steven6095
Default Alternator Output
Working on my sound system - anyone know the amperage produced by the stock alt?
How much headroom once you start subtracting AC , etc.
Steven
Old May 12, 2005 | 02:21 PM
delurker's Avatar
delurker
Default RE: Alternator Output
Stocker is 130 amps.
Old Apr 26, 2007 | 04:45 PM
James Cole's Avatar
James Cole
Want to know this as well, can an audio install of about 600watts diminish the GT performance? Bring problems?
Old Apr 26, 2007 | 05:43 PM
bascho's Avatar
bascho
ORIGINAL: James Cole
It shouldn't since the alternator used in the GT is the same whether you have the base level stereo or the Shaker 1000.
Old Apr 26, 2007 | 06:38 PM
Aziraphale's Avatar
Aziraphale
ORIGINAL: delurker
Wow, I didn't realize it was that high, that's pretty good!
Then again, i never really thought about it needing to be that high since I wasn't factoring the the Shaker1000.
For the record, in my old jeep (I believe it had a 110-120 amp alternator), I ran a 100 watt RMS amp and a 500 watt RMS amp without capacitors and they both ran fine. Very minor if any dimming of lights on huge bass hits. Anyone putting in a system should be able to get away with a good deal more than if you owned a honda
Old Apr 26, 2007 | 11:28 PM
James Cole's Avatar
James Cole
So what can I expect in problems by adding a 800 watt system to the mustang? even very very very minor ones...
Old Apr 26, 2007 | 11:29 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
130 AMPs and has 14v output as well! Not bad IMO
Old Apr 27, 2007 | 12:32 AM
mygt500's Avatar
mygt500
No you shouldn't have any problems with it at all. Make sure you drive the car to charge the battery and the alternator does the rest. It can handle it. The battery will be a problem though as it sucks if it is the stock one......do a search on dead batterys on the site. It will produce alot of threads. Most of the time it was not the alternator. Can't say with 100% confidence that nothing will go wrong as anythingis possible.
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
breaking
Oct 2, 2015 01:27 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
cbird1177711
Sep 3, 2015 08:43 PM
