Cast/Camber Plates?
great!
it would be great to get some feedback though
i have noticed that people dont like to talk much about the alignment stuff
hopefully some people will chime in soon, because i am all ready to install the panhard bar.
This isn't rocket science. On the rear, as long as the left tire is not extending past the fender you can drive it as hard as you like. Regards the front, again, drive it as hard as you want, having negative camber will actually improve the handling. The only draw back is it will eventually wear the insides of your front tires. So...as long as you dont take months to get the alignment you will be fine. I drive my car with -2 degrees of camber full time because Im willing to trade the tire wear for the better handling.
IMO, you want the axle at least reasonably well centered before getting the alignment, if only because the alignment setup puts heads/targets on all four wheels and I don't know if/how an off-center axle is handled. I will ask you if you drove the car a little after lowering it but before measuring/looking at it, and what sort of "before" measurements you may have taken (car weight on rear wheels, one or both sides jacked up and supported by the frame, etc.). What I'm hoping is that your before and after observations were made under the same conditions, though I suspect that they were not.
Please have a little patience. Or start a new thread in the 4.6L Handling section where things like alignment are more commonly discussed (and where this thread probably belongs).
Norm
Hey guys I went through some of this not too long ago. I have eibach pro's on my car. I ended up going with the Steeda HD upper strut mounts that are adjustable. Some answers to the questions below:
1. Yes, drive it for a couple of days so the suspension settles.
2. You can choose to align or not. Your camber is going to be off, do you really want to pay for alignment twice? Get the plates or the bolts, then align....just my .02
3. I have a pair of bolts if anyone needs.....
Hope this helps!
Hope this helps!
I got the plates because I do some spirited driving from time to time, so I thought to go with the heavy duty option. If you need the bolts, PM me.
I initially had the bolts installed by the shop doing the alignment. I did hear that under hard driving and shocks to the front end the bolts can shift over time (I like to road race the car from time to time). This is why I decided to get the plates. I felt over time the bolts would shift, if this happens I would need an alignment everytime the bolts shifted. Don't get me wrong I know plenty of people that have the bolts and never had a problem, so don't worry. They are safe as well.
I took the bolts out myself, and put the stock ones back on. I had Steeda install the plates and align the car. Having changed my springs out myself, it's not a hard job.
Mike
