Vert owners, check out the CDC light bar!
RE: Vert owners, check out the CDC light bar!
You will find the installation instructions for the lite-bar on their home page in the "tech/install" section (I think). It is a bolt-on, look-good accessory type thing. Simple installation, even a snot-nosed, high-school ricer could do it. maybe
thanks for the pics Pump
I was debating this a while back, but decided against until I had seen some different angle shots (what a useless shot on the order page). Now I can say, it's just not my cup of tea.
ORIGINAL: Professor Wizard
Having the roll bar would make it real easy to have a mesh windbreak to stop the turbulance. I had a wind break in my BMW and it made it so calm in the drivers seat....
Yes, mine is the cdc. Install was pretty simple, took maybe an hour. You have to drill 2 holes on each side for the mounting bracket, then a 2" hole on each side thru the plastic for the bar to go thru. The led brakelight is super bright, it lights up cars behind you at night so much you can see the people inside. Im happy with it.
ORIGINAL: gettna05!
