can i syphon some gas?
i may have purchased some bad gas. car started to lose power like the butterflies are not opening? seemed to be alot of hesitation(like gradual 5 seconds) after i mash the throttle. can i syphon some out with a small hose?
you also have 2 tanks that are connected. One on each side of the hump. If it was bad gas you will need to pull the tank and drain, unless there is some other method... maybe pulling the fuel pumps and siphoning through there?
The easiest way to remove gas from the tank (without dropping the tank or drilling a hole in it) is to pull the fuel pump out, then siphon it out. Yeah, its a pain in the butt, but it is the least frustrating way to do it.
The problem still may not be bad gas, however. So be prepared for a letdown if you go through with it and it still has a problem. A bunch of things could cause what you describe. Is the check engine light on?
This would definetly be the easiest way and actually it isn't all that hard. The rear seats come out very easy. There are a couple of push tabs that release the lower cushions and the thing pulls out. You can get to you pump right after doing so. Good luck.
